Author Topic: 'P' gear  (Read 23958 times)
Offline derrick213
'P' gear
« on: May 07, 2012, 12:16:13 AM »
When gear put to 'P' will the car still roll / move??
because mine sometimes does, but sometimes does not.... driving CVT latio  :confused1: :confused1:
Re: 'P' gear
« Reply #1 on: May 07, 2012, 08:44:12 AM »
if the slope is steep, then yes.
Re: 'P' gear
« Reply #2 on: May 07, 2012, 09:26:15 PM »
hi bro,the proper way is to step on the foot brake, activate ur parking brake(hand brake)  then u select ur gear to 'P' position.by doing this u will not damaged ur safety device inside the gearbox.cos if u don't activate ur parking first,ur car will rolled back or forward,there will be a force acting on the safety device,sometimes u will have problem selecting ur lever from 'P' to 'D'.
Re: 'P' gear
« Reply #3 on: May 07, 2012, 09:38:30 PM »
Now I know ...... sheeesh.
Always shift to P before engage foot brake. No wonder morning sometimes difficult to engage from P to D liao.  :crying:
Re: 'P' gear
« Reply #4 on: May 07, 2012, 09:46:09 PM »
NO bro,it's applied ur parking brake(hand brake for some cars) then u put ur gear lever to 'P'.
Offline derrick213
Re: 'P' gear
« Reply #5 on: May 07, 2012, 10:21:14 PM »
means i've been doing it wrong for so long....  :ohmy: :ohmy:
from P to D also is not very smooth...... :scared:
thx bro for the advise,... hope i have not damage my gearbox.... :pray: :pray:
« Last Edit: May 07, 2012, 10:22:50 PM by derrick213 »
Offline jovially
Re: 'P' gear
« Reply #6 on: May 08, 2012, 08:26:48 AM »
This apply to normal parking too? or only at slope?
So the proper way should be:-
After go into a parking lot, step on the foot brake. then shift to "P" position.
Re: 'P' gear
« Reply #7 on: May 08, 2012, 08:45:13 AM »
to be frank, for my coming to 6 years old latio, i always put to P, then step on footbrake.
Re: 'P' gear
« Reply #8 on: May 08, 2012, 04:31:23 PM »
same same for my 7yrs latio
Re: 'P' gear
« Reply #9 on: May 08, 2012, 05:24:38 PM »
Kelvin, i think latio do not have hand brake, only foot brake = hand brake.
I think what you mean is to depress our normal brake before shifting gear is it?
Re: 'P' gear
« Reply #10 on: May 08, 2012, 07:09:03 PM »
yes,correct,that is what i mean.For some cars is handbrake.
Offline d.titan
Re: 'P' gear
« Reply #11 on: May 08, 2012, 08:51:29 PM »
Normally do not use foot brake unless on slope,
Jus put to P on flat ground
 :smile:
Re: 'P' gear
« Reply #12 on: May 08, 2012, 09:20:45 PM »
Correct, what I meant is all along I have been doing is shift to P before depress foot brake, that explain why sometimes morning I having difficulties in engaging from P to D. That why I sheeesh after reading your explanation.
Hope I did not confuse fellow forumers here.
Offline fessm
    • Shopping for ladies
  • Car Color: Red
Re: 'P' gear
« Reply #13 on: August 22, 2012, 02:21:01 PM »
Hey Kelvin,
Me same as Jazz, it is difficult to change from P to D when I used the opposite way.
Sometimes used quite a bit of force to change P to D...
Until now then I saw your correct method.  :ohmy:
What I wish to ask is, have I damaged the gearbox or the safety device?  :confused1:
Can the safety device alone be changed if it really spoils, or must change whole gb?
Jason
Re: 'P' gear
« Reply #14 on: August 22, 2012, 09:05:21 PM »
Hey Kelvin,
Jason
You are scaring me.  :crying:
Offline fessm
  • Car Color: Red
Re: 'P' gear
« Reply #15 on: August 23, 2012, 12:28:32 PM »
Hahaha, got question so must ask ma...
 :D :D :D
Offline ckmckm
Re: 'P' gear
« Reply #16 on: August 24, 2012, 04:23:11 PM »
I have tried the method advise by Kelvin.
That is, step on the foot brake, while stepping on the foot brake, engage the parking braking, then engage the P gear.
I think a lot of us need some time to change to this method.
Really can't get use to it.
Normally, we will engage the reverse gear to reverse into the parking lot.
Then we will conveniently engage the P gear and then step on the parking brake.
It will take some time to change the momentum
Hahaha
Offline pmet
Re: 'P' gear
« Reply #17 on: August 24, 2012, 09:24:34 PM »
I tell you a better method which I've been using for over 4yrs without a prob and this will ensure that you can shift from P to D easily (no stress on the GB):
1. From D or R, change to N (brakes on -- not your handbrake/footbrake)
2. Turn off engine (brakes on -- not your handbrake/footbrake)
3. From N to P (brakes on -- not your handbrake/footbrake)
4. Step on footbrake and release your brakes
The rationale is that the engine while still on will cause the car to move slightly when you shift to P and that will cause unnecessary stress on the GB. Try it.
Re: 'P' gear
« Reply #18 on: August 25, 2012, 09:46:29 AM »
Wah din knw dat engagin hand/foot parkin brake still got so many theory in doin it ah.
Tink its better to protect our gb & all other aspects of maintainin our ride, given è sky high Coe prices of car. Not like last time suka suka change car as & when we feel like.
Even preowned cars r priced very high now.
Re: 'P' gear
« Reply #19 on: August 29, 2012, 07:11:06 PM »
When u feel resistance shifting frm P to D realease the foot brakes n brakes let it roll a little either back or forth then engage brake padel to shift gear, works most of time. But sometimes still kena ni choice got to force, which i hate it
Gd practice is shift to N then P will prevent that situation most of time. If D straight to P esp on a slopes u will feel resistence, allow the rolling a little, u wun crash. :smile:
