Author Topic: Battery Water  (Read 22398 times)
Re: Battery Water
« Reply #20 on: June 27, 2008, 01:53:01 PM »
actually distilled water is used to top-up battery and so it is usually called battery water
however, in other thread, some prefer to use distilled water to also top up the radiator in the belief that it will not cause rusting
fyi, I had not topped up the water for the radiator/reservoir for almost 4 years for my previous car as the level had been near max for long time
ic. thanks for explaining. appreciate that.
oh, your car is so powerful.
Re: Battery Water
« Reply #21 on: June 27, 2008, 02:14:45 PM »
It's a Sunny
maybe, I am lucky - no leakage ........
HJB
Re: Battery Water
« Reply #22 on: June 27, 2008, 03:28:31 PM »
It's a Sunny
who needs distilled water look for me at tonite's meetup .. .still got half bottle left.
Re: Battery Water
« Reply #23 on: June 30, 2008, 12:44:37 PM »
It's a Sunny
hi silver
i confirmed mine has no leakage too.
i topup my coolant reservior to "max level" (abt 1inch from the level to max level), with tap water.
if confirmed that distilled water can be used and it's better/BEST for coolant reservior and RADIATOR, then i will spend man!!!
regards.
Re: Battery Water
« Reply #24 on: June 30, 2008, 12:57:05 PM »
tap water is just water with some minerals
rust formation (oxidation) occurs when you have metals, water and oxygen present
coolant (the green stuff) usually contain rust inhibitors
so it is okay to use clean tap water instead of distilled water unless you "tong poh" your car .......
Re: Battery Water
« Reply #25 on: June 30, 2008, 02:11:44 PM »
Dont anyhow mix lah, now no leakage is good, dont mix here & there, later your radiator pik jar, susa lah~
Btw, got confused, the thread topic from battery water to coolant liao. haha
Re: Battery Water
« Reply #26 on: June 30, 2008, 02:39:38 PM »
Hi Silver,
Oh, no tong poh, so, just let it be liao, use tap water!!!
Guys, confirmed liao, use TAP WATER to topup for our Coolant reservior.
In fact, we should topup through RADIATOR right? instead of Coolant Reservior?
Re: Battery Water
« Reply #27 on: June 30, 2008, 02:41:08 PM »
NSman,
Oh ya, si bei paiseh liao.
May be confused and luan liao.
May be both are related liao, coz linked to distilled water mah :)
For coolant related matters, please refer to coolant...
In Malaysia, distilled water is selling around RM1.xx!!! Ex man!
