Author Topic: Help needed from 50-60,000Km CVT latio owners  (Read 40233 times)
bszayne
Re: Help needed from 50-60,000Km CVT latio owners
« Reply #40 on: March 27, 2009, 10:57:41 PM »
its good 2 invest in a atf cooler 4 the auto box as auto oil could get heated easily under hard driving or jam
Offline liewks
« Reply #41 on: March 28, 2009, 09:16:33 PM »
Might be a throttle body problem rather than the CVT. Makes the car jerk when moving slowly, engine revs but seems to have zero torque and the idle is flaky...
Offline leclub
Fuel float
« Reply #42 on: July 23, 2009, 04:53:22 PM »
Ok. I have my story too. My car currently at 45K mileage. Around 35+ period, a numerous problems with my CVT ride.
Below are my fair shares:
 - Rear drum brake knocking sound with slight braking (Renew drum brake assembly)
 - Loud humming sound from aircon compressor (Renew compressor and refill freon gas)
 - Knocking sound from steerting (Renew steering shaft & snap ring)
 - Engine pinging (Renew ECM)
 - Fuel guage not accurate (Renew fuel float)
 - Engine vibration & knocking sound when accelerate (Renew engine mounting insulator)
 - Power loss - (Renew CVT transmission assembly)
 - Belt noise - (Renew belt shaft, bracket, pulley & retension belt)
Up to date, I still having the engine pinging and knocking sound when accelerate. I will need to go and bug them again. I am not sure if it's just my car only or it is normal since I do not have any other CVT Latio to compare with.  :unsure:
haha... i juz went on my 70km services and replace the fuel float.
Those that experience their Latio fuel indicator dropping from Full to in between 3/4 after driving for a few km better go & change while still under warranty  ;D
Offline maverick_2007
Re: Fuel float
« Reply #43 on: August 30, 2009, 01:33:53 PM »
I suspect my car having this fuel gauge problem... Any idea how much they charge if warranty expire ?
