Author Topic: Any Latio on SPC fuel ...  (Read 16748 times)
Offline CamholicX
  • Redline (6000 rpm)
« on: April 06, 2010, 12:02:50 AM »
can share is yr FC good ?
Offline redman
Re: Any Latio on SPC fuel ...
« Reply #1 on: April 06, 2010, 02:44:42 AM »
i am.. spc 95 (red) no good 98 (green) much better.. abt 12km/l for my 5 yrs old latio..
« Reply #2 on: April 06, 2010, 08:10:51 AM »
Frankly speaking, I have used all the 4 brands of petrol b4, no significant difference in fc. Currently using shell coz got company discount mah. I only use 95 or 5000.
« Reply #3 on: April 06, 2010, 10:39:42 AM »
I have tried all brands of fuel - SPC, Shell, Caltex, Esso.
Esso gives me the best mileage, so I am using Esso 5000.
« Reply #4 on: April 06, 2010, 10:51:25 AM »
what is the discount rate you get for SPC? Esso can get 14+% with deviden card. 750pts for $30 petrol.
« Reply #5 on: April 06, 2010, 02:58:48 PM »
I don't use Citibank Dividend card anymore, but use DBS Esso card to enjoy direct 12% discount.
I discovered that Citibank had miscalculated my rebate amount and I am getting less rebate than what I am entitled to. It happened to few of my friends too.
Offline kgleo
« Reply #6 on: April 06, 2010, 09:23:25 PM »
Me on SPC since day 1. Cheapest in the market.
« Reply #7 on: April 06, 2010, 10:17:29 PM »
me on SPC 92, caltex 92
between these 2 .. i find that spc 92 give me better mileage (FC= 12.1km/l) while caltex is FC 11.5km/l
but not significant leh haha
so i just use SPC.. to save $$$ while use caltex to chalk abit of points to my credit card..
« Reply #8 on: April 07, 2010, 11:41:24 AM »
I pump Esso
12% direct discount using DBS Esso card with  a further 3% discount when I redeem 750 points for $30 worth of petrol ($1.25 = 1 point).
Total 15% discount.
How many % discount do you get at SPC?
Offline ninervictor
  • 9V
« Reply #9 on: April 07, 2010, 03:35:54 PM »
spc 95. best FC for my latio 3yrs
13-14km/l
mix highway and city...imo latio most efficient when cruising at 100kph and one should occasionally goes up to 4-5krpm and 120-140kph to work the engine and let the onboard chip learn...
if i drive slowly... my car eats petrol faster...
Offline ahboon
« Reply #10 on: April 09, 2010, 04:37:58 PM »
using SPC 95. can hit 14.95km/l for my previous tank haha. Mostly highway driving though.
« Reply #11 on: April 09, 2010, 11:15:10 PM »
13-14km/l
How can be most efficient at 100kph with strong wind resistance and high rpm? Are you cvt or 4at?
Offline MadMatty
« Reply #12 on: April 11, 2010, 01:09:46 PM »
My ride is coming up to the two year mark in 3 months time. So far beginning used only 95 from Esso and now switched to 92...don't see any significant difference cos my average FC is still 11.00 to 11.5km/ltr.
Offline vypez
    • need help with words?
« Reply #13 on: April 12, 2010, 10:57:46 AM »
misconception that driving slowly saves fuel.
if you look at charts, when the car is in the overdrive gear and going at optimum speeds, it consumes the least.
1 2 and 3rd gear consumes more petrol as they are considered "picking up" gears.
cheers bro.
you will be surprised at the fc you get when you drive normally and not extremely frugally.
i used to clock 12km/l on my latio, 30% city, 70% highway, and half the time i am on wideopen throttle and high rpms to pick up and when i reach 90km/h, i just cruise..
« Reply #14 on: April 12, 2010, 06:37:16 PM »
cheers bro.
I agree, but optimum speed for 4AT is around 60km/h, that's the least possible speed for overdrive gear. Wind resistance not very big as well.
Saying Latio most efficient at 100km/h is just wrong, the RPM and wind resistance is too high. Cruising at that speed will only give you 16km/l at most, cruising at 60km/h can get 20+km/l.
Offline machim
« Reply #15 on: April 12, 2010, 09:56:19 PM »
Used to be on 95 but I like to accelerate a bit faster, so changed to 98 liao...
« Reply #16 on: April 13, 2010, 04:13:57 PM »
Does running Latio on higher octane 98RON petrol translate to more power?
Latio min RON required is 92.
« Reply #17 on: April 14, 2010, 11:09:26 PM »
Higher octane rating does NOT give you more power.
Do note some premium petrols like VPower and Techron is RON98 with additives, so the additives might be the one giving you power, not the higher grade petrol.
Offline Everince
« Reply #18 on: April 15, 2010, 09:59:49 AM »
Had been using SPC 98 since I moved to punggol...not much choice since it the only patrol station around...using the green 98 and so far so good...cheapiest I should say in the market with discount and good mileage too... :yehyeh:
Offline leiquiz
« Reply #19 on: April 19, 2010, 12:57:44 PM »
I have been on SPC 92. Depending on my speed and type of driving, my consumption can vary from 11 - 14 km/l.
Any of the bros here experience 'knocking'?
