Author Topic: Air Con controller mode faulty  (Read 10920 times)
Offline skullcap
  • Car Color: Amethyst Grey
« on: December 30, 2010, 08:03:09 PM »
Hi Bros n Sists, jusy became a new owner of a used Latio. Been having problems with my air con mode button. I can't seem to control the air con vents, on good days air will be coming out from the center vents-nx to the audio player, on bad days air will come out from the leg area n the windscreen area causing it to fog up, n the other vents-nothing! Anybody experiencing this problem n whats the remedy?
Thanks for the replies  ::) ::)
Offline jovially
Re: Air Con controller mode faulty
« Reply #1 on: December 30, 2010, 08:36:38 PM »
check on the air con display, the "mode" is to control the air coming from different area.
Offline skullcap
« Reply #2 on: December 31, 2010, 03:52:21 PM »
Already tried pressing the mode button. It doesn't control the air vents. Anybody encounter such problem with the mode buttton nt responding?
« Reply #3 on: January 06, 2011, 01:30:04 PM »
What did the mode show when u encounter each of these funny behavior?
Offline swarovski latio
« Reply #4 on: January 06, 2011, 03:41:34 PM »
i think it is due to removing the panel without switching off the air con .. i encounter this the other time when i was diamantling a latio to remove some stuff... the solution i applied is off the air con and remove the panel n pull out the two socket behind and plug it back and it works.... hope it helps
Offline skullcap
« Reply #5 on: January 07, 2011, 12:58:54 PM »
The mode shows everything normal, with the arrow pointing at the figure but the air is coming from the leg and windscreen. It stays like that n i have no control over the air coming out. As i keep pressing the mode, the arrow displays like normal, moving from the front, the leg etc...but the air is stuck at the leg n the windscreen. maybe the electronics controlling the vents kaput.......? Help anybody...?
Offline skullcap
« Reply #6 on: January 07, 2011, 01:04:53 PM »
Thanks for replying but I not really a DIY person. Do u know of any w/s i can go to get this checked...pfefebly someone who is familar with latio?
« Reply #7 on: January 19, 2011, 10:12:37 AM »
Hi skullcap,
Sorry for the late reply.
If your ride under warranty (within 3yrs or 100K, whichever comes first), send in to Tan Chong to take a look. When I was servicing at Tan Chong Bukit Timah, I looked for Steven Tay.
If not, if you prefer a Nissan specialist to look at it, you may want to consider Autosavers (am servicing my car there).
rgds
Offline skullcap
« Reply #8 on: January 19, 2011, 09:52:36 PM »
Hi Bro, thks 4 ur reply. Nope, my car nt under warranty anymore but will try n go autosavers instead. Will update if problem solved
Cheers!
Offline skullcap
« Reply #9 on: January 20, 2011, 01:50:04 PM »
Hi Bros,
My air con controller mode fixed ord. Sent car to TC@ubi. Bro Alongohek, when i saw ur reply last nite car ord in w/s @ ubi but will keep ur advice handy. Had to leave car overnite coz they cannot find problem.Finally collect car just now n they say problem was wiring. The problem wth getting pre-owned cars are you find out more things as you drive the car longer. In my case I found a shocking fact. The distance travelled is not what it seems....by way a loooooottt  :scared: :scared:
Just to remind bros out there if planning to get pre-owned vehicle check carefully before commiting. Thing are not what it seems.
Anyways my problem solved ord. Thanks for all the bros replies out there.
CHEERIOO!!
« Reply #10 on: January 20, 2011, 02:18:20 PM »
Hi Bros,
CHEERIOO!!
how much did TC charge u?
Offline Enzoni
« Reply #11 on: January 20, 2011, 05:53:11 PM »
Hi Bros,
CHEERIOO!!
heard from my car salesman fren, the odometer can be altered for a small sum of money..
so be careful when the pre-owned car u wanna buy got ridiculously low mileage
Offline skullcap
« Reply #12 on: January 21, 2011, 05:21:17 PM »
Hi bros,
The repair at TC cost me $75 n ya...I think meter tampering is a common thing. When I exchange my previous car for dis
Latio found out my ex car's meter was also
altered. Hai....a lot of crooked ppl out there
