Author Topic: reset ecu  (Read 12464 times)
Offline alghojo
reset ecu
« on: January 16, 2011, 09:35:50 PM »
I have tried resetting the ecu using this method, found here http://forum.thelatioclub.org/index.php/topic,6305.0.html
1. Ignition "ON", count to 3.
2. Depress/Release pedal 5 times...hard and fast.
3. Count to 10 (not 7!) and fully depress pedal
4. Count to 12 (SES should be blinking), release pedal
5. Count to 10, depress pedal
6. Count to 10, release pedal.
7. Turn off ignition, then start engine. Done!
On step 4, the SES is blinking. The SES still blinking while going thru step 5 & 6. Was my reset successful?
Offline crusty69
Re: reset ecu
« Reply #1 on: January 17, 2011, 12:10:28 AM »
u shld keep on pressing acc pedal until the CEL stops blinking
once CEL stops blinking then start ignition
Offline alghojo
Re: reset ecu
« Reply #2 on: January 17, 2011, 07:32:42 AM »
ok noted, will try again
Offline speedster
Re: reset ecu
« Reply #3 on: January 17, 2011, 01:33:14 PM »
at which step should the crl stop blinking?  :confused1:
Offline crusty69
Re: reset ecu
« Reply #4 on: January 17, 2011, 02:18:54 PM »
at step 4, after pressing the acc pedal for a couple of seconds, the CEL will blink.
Continue pressing the acc pedal until the CEL becomes steady again.
After tat, release pedal and turn on ignition.
Offline alghojo
Re: reset ecu
« Reply #5 on: January 17, 2011, 07:06:25 PM »
so to say, dont need to release the pedal at 12 sec? just press till it stop blinking?
Offline crusty69
Re: reset ecu
« Reply #6 on: January 17, 2011, 07:39:22 PM »
yup
Offline alghojo
Re: reset ecu
« Reply #7 on: January 17, 2011, 09:00:48 PM »
if tats the case, step 5 & 6 no need to do?
Offline crusty69
Re: reset ecu
« Reply #8 on: January 17, 2011, 10:58:37 PM »
yup
Offline alghojo
Re: reset ecu
« Reply #9 on: January 23, 2011, 08:41:19 AM »
 tried to reset again and this time after the CEL blinks, it does not becomes steady but instead it stops and blink a bit faster and repeat itself. I cannot make the blink steady. any comment?
Offline CamholicX
  • Redline (6000 rpm)
Re: reset ecu
« Reply #10 on: May 31, 2013, 01:12:08 PM »
Is it normal for fc to increase after ecu reset
Offline bigblooo
Re: reset ecu
« Reply #11 on: June 21, 2013, 03:35:01 PM »
The ECU has a self learning curve and it is normal to have slightly higher consumption for the first 80Km or so , or at least in my case.
So once it learns you driving style , it should revert back to pre reset.
Other brothers here may have different findings.
« Last Edit: June 21, 2013, 05:40:28 PM by bigblooo »
