Air-con not so cold. Need to bypass heater
<< < (2/3) > >>
Roy:
Will it stress & shorten the compressor lifespan?
Silver:
did he do some wiring to by-pass the thermostat?
so if the cabin temperature is too low, can you still use thermostat to adjust the temperature?
CustomGolf:
In the panel between the engine and you are pipes where water from the radiator will flow to when you increase the temperature so that the air blower will blow out warmer air, this is bypassed, did that when my ride was 3 months old but reverted because my wife don't like it to be too cold.
RG:
Any Pros and Cons? seems interesting..
CustomGolf:
I've heard that in case of emergency, if your radiator fan dies on you, you can actually turn up the heater in your air con system to cool down your engine like a backup radiattor but you'll be getting all the hot air, no personal experience and hope not to.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
