air con blowing warm air at 25deg and above
dl25:
I do have the same problem last year a few month before warrenty expire. My air con only blown out warm air no matter what temp I adjust.
Sent to TCM to check, found out evaporator faulty and replaced for me FOC. Think you should sent your car for checking to clear your doubts. :out:
snuffablescoopy:
my air con blows out cool air when i lower the temp, so i suspect it's cuz the thermostat turning off the cooling when the temp has reached. Anyway, changed to a brand new air-con set, and tested it out, still blows warm air when i go above a certain temp...and cool air when i go below tat temp...
kelvin:
hi there, hot .no it's warm air i can say,right.that is normal .that is the heater . ::)
idone2u:
There are two reasons:
your aircon got problem.. check with aircon people ... maybe filter dirty, no coolant etc...
or at 25 degrees or higher it is suppose to be warm air - I use it a lot during heavy rain.. when I am all wet... to dry my shoes!!
Jazz:
Think IIRC, there a thread regarding this topic quite sometimes ago, my personal experience, if normal hot and humid days should be o.k, but if encountered few days raining and the outside ambient temperature is cooling, if you set your aircon temp higher that the outside temp it will blow warm air, so if you want to be cold, you have to set 20 or 18 degC.
Navigation
[0] Message Index
[*] Previous page
Go to full version
