Author Topic: Clicking sound coming from steering wheel  (Read 6970 times)
Offline bugatti
« on: May 20, 2011, 09:38:45 AM »
Hello all, I noticed that there is a soft clicking sound coming from the steering wheel whenever I am turning. Anybody can advise what could be the problem? Thanks.
Offline jovially
Re: Clicking sound coming from steering wheel
« Reply #1 on: May 20, 2011, 09:57:26 AM »
Is your signal light turn on?
Offline bugatti
« Reply #2 on: May 20, 2011, 02:04:16 PM »
nope. The signal light is not on.
« Reply #3 on: May 20, 2011, 06:36:00 PM »
this is normal as its linked to the auto signal cancellation. unless you hear a tok tok sound, then its the steering coupling
« Reply #4 on: May 21, 2011, 12:57:10 AM »
its Very common complain among lations, all time hot issue discuss over here... if its still bearable juz live wif it, if not brin it dwn to tcm 4 part replacement.
Offline Blim
« Reply #5 on: May 21, 2011, 11:34:58 AM »
any advise on the cost if replace in TCM or other recommended workshops.. thanks :thumbsup:
Offline jovially
« Reply #6 on: May 21, 2011, 01:39:45 PM »
What I mean is when you make a right turn, usually you will give a right turn signal, and you will hear a click sound, this should be normal as mentioned by kspchew, unless it is a tok tok sound. then is related to steering coupling.
Offline bugatti
« Reply #7 on: May 21, 2011, 05:44:08 PM »
Hi, thanks for the comments. Funny thing is that the clicking sound comes up when I did not use the signal light. Hopefully the tick tick sound does not become a tok tok sound.
