Author Topic: When to change to xw40 engine oil  (Read 12536 times)
« on: August 27, 2011, 11:42:59 PM »
Any advise opinion welcome thanks
Re: When to change to xw40 engine oil
« Reply #1 on: August 28, 2011, 01:15:23 AM »
Been using this grade since collect new car......
« Reply #2 on: August 28, 2011, 05:31:44 PM »
 Yeap, using w40 since I collected the car. It give better protection when you drive long distance.
« Reply #3 on: August 28, 2011, 10:47:30 PM »
if your miledge is not that high,can use 0w30
Offline corgan
« Reply #4 on: October 13, 2011, 07:15:00 PM »
W30 oil is sufficient for use in Singapore and occasional drive up north. Change to W40 when you notice engine oil levels start to drop faster than normal.
Offline trex101
« Reply #5 on: October 25, 2011, 04:48:39 PM »
Yes, 0w30 or 5w30 is the correct spec, w40 would be too thick, bad for FC, throttle response and start-up protection.
Your One Stop Oil Shop
www.mxtradings.com
Redline, Amsoil, Pennzoil, Schaeffer
Royal Purple, Mobil 1
NGK & Denso iridium
Duragloss Products
Osram Nightbreaker & Philips X-treme Vision
Offline Enzoni
« Reply #6 on: October 25, 2011, 08:43:57 PM »
I beg to differ, Redline 5w30 is too thin for my liking. Amsoil is slightly thicker. Using Mobil1 0w40 now, FC remains good, throttle response very good, engine seems smoother n quieter. Only bad point is startup takes abit longer than redline.
Offline trex101
« Reply #7 on: October 26, 2011, 05:03:06 AM »
Redline and Amsoil 5w30 are around 10.5cSt at 100'c while M1 0w40 at 13.5cSt, that's about 29% increase in viscosity. The thicker M1 will quiet down the engine but FC might suffer due to higher fluid drag. If it works fine for your Latio, keep using it as you will have the best of both world, quiet engine plus good FC.
www.mxtradings.com
NGK & Denso iridium
Duragloss Products
Offline cutelmo
  • Car Color: AMETHYST GRAY
« Reply #8 on: October 27, 2011, 11:13:46 AM »
How do you consider if the millage is high? 100K?
So for a 50K servicing, which would be best ideal?
5W30 or 5W40? Please advise. Thanks.
Offline trex101
« Reply #9 on: October 27, 2011, 11:27:58 AM »
Depends on your engine condition really, if use good quality synthetic from day one, around 150-200k would be consider high mileage but if using cheap supermarket synthetic then maybe by 80-100k already consider old.
If you track/monitor your FC from day 1, usually your FC will peak after 20-30k km run-in, it should maintain the same FC till around 100-150k.
The best method is to keep your engine clean and in good condition from day 1, then you don't have to worry for the rest of your COE period.
www.mxtradings.com
NGK & Denso iridium
Duragloss Products
Offline cutelmo
« Reply #10 on: October 27, 2011, 02:36:27 PM »
I bought my latio as 2nd hand. So not sure if the previous owner have take good care of it.
« Reply #11 on: October 27, 2011, 04:05:50 PM »
in this case, use w40 oil. I have been using this for the past few servicing, quiet engine and FC no difference.
Offline cutelmo
« Reply #12 on: October 28, 2011, 09:15:31 AM »
Thanks dsrio.
« Reply #13 on: October 30, 2011, 10:43:56 AM »
Can share your mileage incurred?
« Reply #14 on: October 31, 2011, 08:08:54 AM »
my milage above 90k near 5 year car.
been using w40 since i started servicing at outside TCM after my NPMP finsihed.
