1k Servicing
clarence:
For once, you are right! :thumbsup:
This, iagree with you. :bleh:
david1881:
You lucky fella. No other rectification needed for your car. :thumbsup:
duxton88:
The worksheet showed oil filter and engine oil change. There was also a slip of paper showing the battery test results.
Actually there was some niggling problems when I collected the car. I noticed the driver's side of the side beam (where the tweeter was placed) wasn't fitted flush with the dash board and the small piece of triangular cover that has some ventilating holes. In fact the small triangular piece and side beam disconnected after 2 days of driving and I had to spend some time pushing them to join back together... LOL.
Also noticed that sometimes when I stepped on the brake at low speed there is excessive vibration. Think will highlight to the SA at 5k servicing if the problem worsens.
clarence:
Better to highlight to SA before problem worsens.
duxton88:
Thanks Clarence for the advice.
Navigation
[0] Message Index
[*] Previous page
Go to full version
