My FC Getting Better With Low RPM
limck007:
--- Quote from: clarence on December 03, 2008, 03:34:47 PM ---Very impressive.
:thumbsup: :thumbsup: :thumbsup:
Your Latio is really one in a million. :thumbsup: :thumbsup: :thumbsup:
Even when I just drive alone, mostly highway driving, never rev above 2500rpm, travel at 80km/h, air con thermostat set at 26 degrees, best I got was 14km/l.
--- End quote ---
let me join ur club.. FC of 12 niah ... even with same driving habits...
nwo reaching 8K mileage and still on mineral oil
Toalson:
--- Quote from: rooneytoon2004 on December 05, 2008, 10:17:27 PM ---bro..care tell me how old is ur getz?
so did u trade it to TCM n how much did they offer u above scrape value?
--- End quote ---
Mine a 4yr coming to 5yr and TCM say 0.... :glare: And dont noe why gong gong still take. haiz
LatioR:
--- Quote from: limck007 on December 05, 2008, 11:07:11 PM ---let me join ur club.. FC of 12 niah ... even with same driving habits...
--- End quote ---
hi bro, yr car still very new and sb able to hv better FC rite? Or u must be cheongter then? Mine > 3yrs now with best achievement of 13.5+KM/l in local and ~17+km/l 100% on malaysia NSHW. Do follow some tips given by some fellow lations for better FC. :smile:
liewks:
When you floor the pedal to hit 5K+ rpm, the engine has to go into open-loop mode momentarily. That is not really a fuel saving technique. While throttle losses are reduced, excess fuel is used to cool the engine to avoid detonation (engine burns rich when > 3/4 throttle). Also high rpms increase losses due to friction.
It is generally agreed that shifting up at low rpm in MT equipped cars is the most efficient way to accelerate. This does not mean that you need to use light throttle. Opening the throttle while keeping engine RPM low minimises throttle loss. I am not sure if 5k+ rpm on an AT has the same effect. You might be able to get 18~19km/L.
Anyway, the ECU & TCM will ensure that the engine is never "dragged".
--- Quote from: fri13th on November 30, 2008, 12:27:13 PM --- Yah i think its best to press harder and reach cruising speed fast and than let the gear auto shift into the highest gear when u reach cruising speed rather than dragging the engine along at low rpm is a waste of time and maybe fuel too :confused1: for me i quite often press until 5k+ rpm to reach cruising speeds in expressways and i am getting consistent good FC of 17/18km/litre :yehyeh:
--- End quote ---
clarence:
--- Quote from: liewks on December 11, 2008, 01:01:46 PM ---When you floor the pedal to hit 5K+ rpm, the engine has to go into open-loop mode momentarily. That is not really a fuel saving technique. While throttle losses are reduced, excess fuel is used to cool the engine to avoid detonation (engine burns rich when > 3/4 throttle). Also high rpms increase losses due to friction.
--- End quote ---
No matter how hard I try, I can never achieve 18 to 19km/l when I drag my engine beyond 5,000rpm. Is there a special technique to achieve this?
I get 10+km/l at best if I drag the engine beyond 5,000rpm.
When I drag past 5,000rpm, by 2nd gear, I am almost at 100km/h.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
