Battery & Accelerator
iagree:
--- Quote from: vortex on March 26, 2009, 03:56:59 PM ---If u can beat a BWM, it means that they see us not even qualify to compete with them. Otherwise a BMW would not cost 3 times as much than a latio.
--- End quote ---
hi vortex
i have to AGREE with you leh :)
BWM vs BMW? :)
AIya, surely ex stuff is like that but is possible to hv the similar problems leh.
vortex:
--- Quote from: iagree on March 26, 2009, 05:38:27 PM ---hi vortex
which type of oil? engine oil? i change it 2mths ago (before cny) leh.
chg @ tcm using my NPMP.
regards.
--- End quote ---
Wat i meant is the cvt transmission oil. They are people who needs to change it more frequently (think less than the scheduled 40k interval, not sure cause mine is the 4AT), and even the gear box. There is some mentions of it in this forum. There are also people who already driven for 4 years without problem.
clarence:
--- Quote from: iagree on March 26, 2009, 05:41:45 PM ---h clarence,
not sure leh.
when i had my 37000km service with tcm in Jan09. i thk they do check my tyres n pump air.
last mth, i did chk n pump once before, nothing much to add / pump in leh. how ah?
inflated is? meaning, let go all the air and repump the fresh new air into the 4 tyres?
thanks.
--- End quote ---
I meant you should check if your tyres have sufficient air, at the recommended tyre pressure.
For me, I pump 230KPa for front and back tyres when tyres are cold.
iagree:
--- Quote from: clarence on March 27, 2009, 09:42:00 AM ---I meant you should check if your tyres have sufficient air, at the recommended tyre pressure.
--- End quote ---
hi clarence
ic. that is inflated? thanks for info.
230kpa? last thurs, i pumped it at ard this pressure aso. but i thk i drove for 20km b4 i pump.
donno how.
fri13th:
--- Quote from: vortex on March 27, 2009, 08:08:14 AM ---Wat i meant is the cvt transmission oil. They are people who needs to change it more frequently (think less than the scheduled 40k interval, not sure cause mine is the 4AT), and even the gear box. There is some mentions of it in this forum. There are also people who already driven for 4 years without problem.
--- End quote ---
hi bro actually in theory nissan cvt should be even more maintaince friendly than 4at as the recommended interval is 60k or 3 yrs for cvt oil change :thumbsup:
Navigation
[0] Message Index
[*] Previous page
Go to full version
