Is it ok that the i-key indicator on the odometer keeps blinking?
rayace168:
--- Quote from: Midnight on August 07, 2009, 12:22:06 AM ---i think the immobiliser icon is a shape of a car, red in colour, once u lock the car, it starts blinking. Think it is normal.
--- End quote ---
yeah rite. never really take notice until today. :D bcos it only blinks after u lock the car and the position is in the lower half and middle section, easily hidden by streeling whel.
jliow:
Blinking red means cannot detect key, green means key detected, so dun knwo what color u see blinking, most likely red, so meaning got either phone interference or Signal, (happens when u go Esso stations and with some brand of mobile phone blue tooth) or key batt weak
Kuro:
Ok, thanks all of you for the info. The blinking should be normal that shows the immobiliser is on.
rayace168:
--- Quote from: Kuro on August 08, 2009, 12:12:25 AM ---Ok, thanks all of you for the info. The blinking should be normal that shows the immobiliser is on.
--- End quote ---
hope u not confuse. There are 2 lights we are talking here.
One is the immobiliser light (the one with car icon), should be blinking red after lock.
Another one is the i-key light (the one with key icon), should not be blinking after lock. ;)
moochi:
--- Quote from: Mikal on August 06, 2009, 11:49:26 PM ---If you had been using I-key for two+ years then it's probably the weak battery. Just like my case..
Try changing the I-key battery...simply pry it open with a screw driver and buy a similar replacment battery (I tink it's $2~2.50) at any watson/guardian or cold storage shop. Snap it in and it should be OK.
It worked in my case... ;D
--- End quote ---
Wah... nice tip! Will try it next time. I brought my key to TCM previously and they charge my $20 to replace battery le! :nonod:
Navigation
[0] Message Index
[*] Previous page
Go to full version
