Ikey light keep flashing..
<< < (5/5)
jovially:
--- Quote from: nglipthian on November 19, 2009, 05:21:39 PM ---Just changed my battery today. I discover that there are different battery brand out there and it is better to get back Sony (same with the original one). Before that I bought a "camelion" battery, after changing, green I key keep flashing.
Yesterday went to TC, they check the battery voltage but found nothing wrong with its voltage but Green I key keep flashing. Changing to their battery then no problem. $10.70 for a tiny battery from TC is too ex. So decidede to get it from ABC shop and it cost only $2.
--- End quote ---
a bit confuse. so if i-key (green) keep flashing before starting the engine - normal?
if i-Key (green) keep flashing after start the engine - battery weak?
If i-key (red) keep flashing - cannot detect i-key
baobao:
yo.. just bought a CR2025 battery and replaced it.. quite easy.   :smile:
i measured the old battery and its 2.9v le..  it is still healthy as its a 3v battery..
new one is about 3.2V. but flashing light is off after battery replaced..
wamphyri:
Sometimes I do have that problem but the reason is because I place my ikey in the same pocket as my mobile phone. I think the signal from the mobile phone causes interference with the signal sent my our ikey. I make it a point to put the ikey in the pocket not containing my mobile phone and the problem was solved. :yehyeh:
Hope this helps.
rocket:
--- Quote from: baobao on November 21, 2009, 03:01:48 PM ---yo.. just bought a CR2025 battery and replaced it.. quite easy.   :smile:
--- End quote ---
voltage will be lower than 2.9V with load.
Jo_Lee:
i juz changed my ikey batt today but ikey still act like batt low  :(
the batt i used is not sony brand..it was bought from some pasar malam stall some time back...
think hv to change to sony brand and try again  :(
Navigation
[0] Message Index
[*] Previous page
Go to full version
