Nissan Car Lounge - Almera, Juke, Latio, Qashqai, Sylphy, Teana Owners => Latio => Topic started by: idone2u on February 22, 2010, 10:31:15 AM
Recently I noticed that when I start my car... the green light on the car-key is on.. but it disappeared after about 10min or so...
Somehow I never see it before that last so long....
Is this normal or the battery is weak?
probably the battery is weak
have you changed the battery since you got the car?
try checking the arming/disarming distance using the remote control
if the distance is shorter than before, most likely it is time to change battery
Time to change battery in the I-key liao. It still can last for a while, if continue ignore the green light, one day you will find you can't open the door ...only can use key to open door and start engine.
Ya it's the batt as i recently also have that issue,but after i change the batt no more green light liao :yehyeh:
Confirmed. The flashing symptom is due to weak battery for i-key.
store a few batteries in your compartment and home. you never know when you need especially during urgent situation.
haha.
I don't think there is an urgent situation that makes us not able to draw out the physical key and use it....
where can we get the batteries?
DIYs, stationary, or $1 shops at hdb neighborhood. Only $2 each.
sony cr2025 cheapest i got at $1.50 made in jepun
maxell CR2025 $1.20 Made in Japan
I have a spare one
