Nissan Car Lounge - Almera, Juke, Latio, Qashqai, Sylphy, Teana Owners => Latio => Topic started by: tchekchuan on May 14, 2010, 11:33:09 AM
Hi, nowaday i seem to have problem with the remote sensor on my car.
I need to press the door button a few times then the sensor will activate to unlock and lock the door.
At first i thought is the weak battery on my remote, so i replaced one, but the problem doesnst seem to disappear.
I tried the boot and passenger button as well, and also have the same problem. Did anyone encounters this problem before? What could be the problem? My ride is about 1.5yrs old, if i go TCM will they charge me?
I have the same problem. Change battery as well. But it's intermittent for me. Sometimes it can open from a distance, at times, I have to open the door or boot manually. Car is also about 1.5 years.
No, under warranty.
what you need to observe is does the remote near your hand phone or electronic device?
is that the problem/issue? my remote is right beside my phone! :crying:
i did notice that when my remote together with my hp it will not "sensitive" it could be due to the electronic interference
no leh, i dont put my phone together with the car key, but still not sensitive. i got an extra remote and both also like that.
have u check the sensor cable behind your rear view mirror?? any lose?
any update?
I had that problem for a while but resolved it last week, open up your remote and make sure that your battery is sitting properly in the battery slot, pressed it formly down on the metal ring like catch then put the cover back on. It worked for me.
i tride liao.. still the same.. somemore i got an extra remote also like that leh. sian... see when i free then i go TCM lor..sian...
