Nissan Car Lounge - Almera, Juke, Latio, Qashqai, Sylphy, Teana Owners => Latio => Topic started by: skullcap on December 30, 2010, 08:03:09 PM
Hi Bros n Sists, jusy became a new owner of a used Latio. Been having problems with my air con mode button. I can't seem to control the air con vents, on good days air will be coming out from the center vents-nx to the audio player, on bad days air will come out from the leg area n the windscreen area causing it to fog up, n the other vents-nothing! Anybody experiencing this problem n whats the remedy?
Thanks for the replies ::) ::)
check on the air con display, the "mode" is to control the air coming from different area.
Already tried pressing the mode button. It doesn't control the air vents. Anybody encounter such problem with the mode buttton nt responding?
What did the mode show when u encounter each of these funny behavior?
i think it is due to removing the panel without switching off the air con .. i encounter this the other time when i was diamantling a latio to remove some stuff... the solution i applied is off the air con and remove the panel n pull out the two socket behind and plug it back and it works.... hope it helps
The mode shows everything normal, with the arrow pointing at the figure but the air is coming from the leg and windscreen. It stays like that n i have no control over the air coming out. As i keep pressing the mode, the arrow displays like normal, moving from the front, the leg etc...but the air is stuck at the leg n the windscreen. maybe the electronics controlling the vents kaput.......? Help anybody...?
Thanks for replying but I not really a DIY person. Do u know of any w/s i can go to get this checked...pfefebly someone who is familar with latio?
Hi skullcap,
Sorry for the late reply.
If your ride under warranty (within 3yrs or 100K, whichever comes first), send in to Tan Chong to take a look. When I was servicing at Tan Chong Bukit Timah, I looked for Steven Tay.
If not, if you prefer a Nissan specialist to look at it, you may want to consider Autosavers (am servicing my car there).
rgds
Hi Bro, thks 4 ur reply. Nope, my car nt under warranty anymore but will try n go autosavers instead. Will update if problem solved
Cheers!
Hi Bros,
My air con controller mode fixed ord. Sent car to TC@ubi. Bro Alongohek, when i saw ur reply last nite car ord in w/s @ ubi but will keep ur advice handy. Had to leave car overnite coz they cannot find problem.Finally collect car just now n they say problem was wiring. The problem wth getting pre-owned cars are you find out more things as you drive the car longer. In my case I found a shocking fact. The distance travelled is not what it seems....by way a loooooottt :scared: :scared:
Just to remind bros out there if planning to get pre-owned vehicle check carefully before commiting. Thing are not what it seems.
Anyways my problem solved ord. Thanks for all the bros replies out there.
CHEERIOO!!
Hi Bros,
CHEERIOO!!
how much did TC charge u?
Hi Bros,
CHEERIOO!!
heard from my car salesman fren, the odometer can be altered for a small sum of money..
so be careful when the pre-owned car u wanna buy got ridiculously low mileage
Hi bros,
The repair at TC cost me $75 n ya...I think meter tampering is a common thing. When I exchange my previous car for dis
Latio found out my ex car's meter was also
altered. Hai....a lot of crooked ppl out there
