Nissan Car Lounge - Almera, Juke, Latio, Qashqai, Sylphy, Teana Owners => Latio => Topic started by: alghojo on January 16, 2011, 09:35:50 PM
Title: reset ecu
Post by: alghojo on January 16, 2011, 09:35:50 PM
I have tried resetting the ecu using this method, found here http://forum.thelatioclub.org/index.php/topic,6305.0.html
1. Ignition "ON", count to 3.
2. Depress/Release pedal 5 times...hard and fast.
3. Count to 10 (not 7!) and fully depress pedal
4. Count to 12 (SES should be blinking), release pedal
5. Count to 10, depress pedal
6. Count to 10, release pedal.
7. Turn off ignition, then start engine. Done!
On step 4, the SES is blinking. The SES still blinking while going thru step 5 & 6. Was my reset successful?
Title: Re: reset ecu
Post by: crusty69 on January 17, 2011, 12:10:28 AM
u shld keep on pressing acc pedal until the CEL stops blinking
once CEL stops blinking then start ignition
Post by: alghojo on January 17, 2011, 07:32:42 AM
ok noted, will try again
Post by: speedster on January 17, 2011, 01:33:14 PM
at which step should the crl stop blinking?  :confused1:
Post by: crusty69 on January 17, 2011, 02:18:54 PM
at step 4, after pressing the acc pedal for a couple of seconds, the CEL will blink.
Continue pressing the acc pedal until the CEL becomes steady again.
After tat, release pedal and turn on ignition.
Post by: alghojo on January 17, 2011, 07:06:25 PM
so to say, dont need to release the pedal at 12 sec? just press till it stop blinking?
Post by: crusty69 on January 17, 2011, 07:39:22 PM
yup
Post by: alghojo on January 17, 2011, 09:00:48 PM
if tats the case, step 5 & 6 no need to do?
Post by: crusty69 on January 17, 2011, 10:58:37 PM
yup
Post by: alghojo on January 23, 2011, 08:41:19 AM
 tried to reset again and this time after the CEL blinks, it does not becomes steady but instead it stops and blink a bit faster and repeat itself. I cannot make the blink steady. any comment?
Post by: CamholicX on May 31, 2013, 01:12:08 PM
Is it normal for fc to increase after ecu reset
Post by: bigblooo on June 21, 2013, 03:35:01 PM
The ECU has a self learning curve and it is normal to have slightly higher consumption for the first 80Km or so , or at least in my case.
So once it learns you driving style , it should revert back to pre reset.
Other brothers here may have different findings.
