Nissan Car Lounge - Almera, Juke, Latio, Qashqai, Sylphy, Teana Owners => Latio => Topic started by: Ryan9413 on November 19, 2011, 02:28:03 PM
Does anybody knows wats the cost to replace the steering Coupling at TCM or Autosaver?
i never even had this thought i just drove to tcm during servicing n tell them to deal with it its a design defect n not wear n tear. told them to see my record 3 yrs change 4 times regrease twice n u want to charge me for it?
in the end they LL change for me foc
iirc the cost at TCM is abt $500+
Wah costly, Is it safe not to change the coupling? Will it cause further damage?
maybe you can try outside workshop to get a quote.
mine since changed a few years back during warranty, so far problem never occur again.
to add on, the mechanic at TCM did tell me before that this steering coupling problem will not affect the car performance or safety, just annoyed at the noise.
Only TCM can do it. Autosavers cannot
There's no safety issue Just bear with the noise and u don't have to spent a single cent
Can try lubricate it someti
me it might help.
Anyone has the problem where the steering wheel will make a of noise and vibrate when going over slightly uneven grounds (eg the slopes with grooves in hdb mscp)?
I have this problem... u need to change the gasket in the front brake assembly .. (brake bracket kit). replace it soon as sometime even dring at high speed the wheels vibrate. it is dangerous. Cost less than $200 with labour.
Thanks. TC lubricated the steering joint instead. Didn't solve the problem. Darn.
Which service centre did you go to where they gave you this diagnosis?
This is exactly what im experiencing. i test drive with TC over strips and uneven grounds. That sa told me its normal ..
Check the cost of changing steering coupling at AS about 300++ but haven include labour, anyone try change there before?
You should let the mechanc take the wheel instead. I let the SA took the wheel, and he proposed lubrication.
Didn't work.
Replace at TC. under warranty.
But think it will come back again.
Told the SA, he say need to get a tech to test drive with me, I told him don't need test drive. it is a known issues.
So at the end they change it for me.
Yes I did have the same problem this problem must get the TC advisor to try your car @ the bukit timah turf city
MCP then they can hear it, this is wat I did after many many time go back to them & during testing they can't hear it cause of the road condition.
What did they do to fix it? Change the steering coupling?
I did at auto saver. they clean the brake coupling(i think) and change the gasket.
This rounnd not the couping is the power streeling motor & 1 more part just bellow the wheel. Try to
go buck & test drive with them if not it will be too costly after warrenty.
I have just found out the name of the parts it is strg module & strg motor, the mentioned parts tooks 4 mth
to deliver from Japan.
Hi bro, How much for these parts?
i can changed the coupling for you guys.(parts and labour).
Just changed my steering coupling 2 weeks ago , bought part at fong tat for $170 den labour charge $25. It's actually very easy to change . Mechanic took about 10 min to change it . Now steeringndamn quiet. Shiok!
care to share which w/s?
Its Called Boon Siong at Autobay at Kaki Bukit. not sure the unit number but its at level 1
Lucky at that time still under warranty :w00t: so sorry I m not too sure how much
Mind to share how to buy the steering coupling? Do we have to tell them the part number? If yes could you please advice the part number?
how much does it cost?
hi guys do you know what is the steering coupling called in chinese? :unsure:
I notice a "thud thud" sound on the front left side of my car when I turn towards right. Sound only visible when I turning up in MSCP. Is that the sound of the steering coupling? does that mean I have to change it?
Just got Bro Kelvin to check for me the sound coming from the front left side. Apparently, the mechanics at TCM did not grease a part of the left disc brake when they replaced the brake pads during the last servicing. Now the sound is gone. Thumbs up for Bro Kelvin!! :yehyeh: :yehyeh:
do you still have the sound after changing the steering coupling?
So which is the problem?
Steering coupling?
Steering joint?
Brakes ?
Gettin confused
The Malaysian forum speaks of updated steering assembly that solved this 'sound' problem
change it in JB, RM300
Steering coupling?
Steering joint?
Brakes ?
Gettin confused
hi bro Black4,bro KT's problem is a different issue,after test drive,found out it no the coupling.
Bro kelvin , would u by now be familiar with the car?
My car have some sound as described by the other bro here
Would u be able to check? How much would u charge for inspection?
hi bro,not problem.just drop me a call and arrange with me the time,i can do a test with u first,then we see what wrong with ur ride.
:yehyeh: :yehyeh: :yehyeh:
Bro ... Kelvin, can check for me as well ? :unsure:
:thumbsup:
How to reach you ? :(
:thumbsup:97114018
:thumbsup: 97114018
SMS sent :thumbsup:
yap,noted.
