Nissan Car Lounge - Almera, Juke, Latio, Qashqai, Sylphy, Teana Owners => Latio => Topic started by: IvanL on May 28, 2012, 08:35:22 PM
Hi bros,
Does anyone encounter this situation before?
I was cleaning my driver's side car mat and i noticed that the underside of it was wet.
I looked back at my compartment under the steering wheel and found the area having a water patch? Is this a problem? :ohmy:
Anyone knows?
Anyone knows?
hi bro come i check for u.
Are you free tml morning bro? ::)
call me or SMS me and i arrange with u the timing,should not be a problem.
Keep us posted what the cause. thanks
I have rectified the problem to the water that leak into the floor board,it's from the a/c ,after doing the cooling coil from other workshop???cos he just bought the car,they did not do it properly causing the water to flow into the driver side floor board. :crycry:
Still monitoring the situation. :weep:
Still seeing water patches in a square shape as seen directly infront of the brakes in the picture posted above..
Using newspapers to absorb the water daily... But better than before... all thanks to kelvin bro.
Doesnt seems like its improving... :unsure:
Quite bad leh, better go back bro Kelvin for follow up check.
yea. :nonod:
thanks bro.
yea. :nonod:
thanks bro.
hey bro,come down i check it for u.if it still leaking then need to do it again.
yea. :nonod:
thanks bro.
I have the same problem before a few months ago... apparently mine is due to the leak in the windscreen. change the whole glass now is fine.
