Nissan Car Lounge - Almera, Juke, Latio, Qashqai, Sylphy, Teana Owners => Latio => Topic started by: joyrob on September 05, 2012, 11:28:20 PM
Hi all
Have reached my 100k milestone. Mechanic advised need to change spark plugs. Quoted 200 for material and labour. Is it expensive for this ? I heard latio spark plugs not easily changed, as have to removed quite a lot of things.
$200 all in is good price, for normal usage drive latio for 10 years only need to change spark plug once at 5 year mark.
Try get the plugs from other source which cost about $110 for a set of 4 and get the workshop that service your car to change. Labour usually charges between $30 to $60.
Total may cost around $150 and the balance can still pump petrol....probably 3/4 tank.
By the way, check with all bros, after changing the spark plugs, do we need to reset the computer unit? Thks!
Yes bro. You need to reset your ecu about $50- 60 usually. I changed my spark plugs at kelvin bro's workshop about 2 months ago.
Will recommend you ask him for a quote.
Cheapest qoute i got for Denso plugs $22.50 per pc
Ngk not advisable to get
I just had my spark plugs replaced Iridium and throttle cleaned. Idling too high but mechanic said to drive for a few days as the computer will usually self-adjust. Your thoughts?
Yep, ECU need to re-learn your driving habit again. No worry.
You may also faced a higher FC for this tank and next.
My spark plugs were replaced without a single charge while I am on NPMP. Worth It
After throttle clean,u need to do a ECM reset.
I have just done my servicing & spark plugs @ Bro kevin workshop last mth. :thumbsup:
On NPMP, change of spark plugs is at which mileage interval, 10K?
Bought a 2nd hand latio, the servicing history didn't indicated any change of sparks plugs.
Car's cuurently up for 54k servicing & TC recommended i go for package B - change of sparkies with additional charges...
Any idea what sparkies to use for latio 4AT?
Spec?
Thanks :thumbsup:
DENSO FXE20HE11
DENSO FXE20HE11
Thanks :thumbsup:
Any npmp users can kindly advice any changes of sparkies during 0~40k mileage?
Thanks :thumbsup:
i am not on npmp but the recommended interval for change is 100K km for the plugs.....
my car is now 180K km and i change at 100K & 160K (cos car left 2yrs so change earler rather than later)
Stock cars no need changevspark plug unless reach 100k. When under npmp it is replace free
