Nissan Car Lounge - Almera, Juke, Latio, Qashqai, Sylphy, Teana Owners => Latio => Topic started by: starushz on March 16, 2014, 12:49:34 PM
Hi guys
Anyone experiencing ur engine pinging and how did u solve it? Mine is make those clack clack clack sound under low throttle low speed situation. Like when u engage a higher gear and engine not enough power and will go clack clack clack.
Tried those fuel cleaner also no use.
Which RON grade of petrol are you using ?
95. But latio is speced to be able to use 92. Thats from the manual
Next you may want to check your spark plug.
The rest need your mechanic to take a look :
1) compression ratio
2) crank shaft bearing
