Nissan Car Lounge - Almera, Juke, Latio, Qashqai, Sylphy, Teana Owners => Latio => Topic started by: Godzilla on November 11, 2009, 10:55:42 PM
Title: ABS lighted up
Post by: Godzilla on November 11, 2009, 10:55:42 PM
Hi fellow Lations,
                      Today my ABS light suddenly stayed lighted after I went for a car wash, any Lations knows what happened. I dont think it's might have anything to do with the car wash, maybe coincident. Pls advice.
Title: Re: ABS lighted up
Post by: latioboy91 on November 11, 2009, 10:59:17 PM
after car wash ur brakes still wet den u brake hard den ABS light on.
Or, the lady who dried your car was too hawt and she had D cups so your car steam and high, then need ABS to control!  :yehyeh: :yehyeh:
Post by: Godzilla on November 11, 2009, 11:05:38 PM
I think the male washers are from Sabah, so my Latio got no reason to react. Anyway, after the wash I did not even have chance to brake hard. If ABS is activated, will the light be deactivated after it "stand down". Mine is lighted all the way, could it be the ABS faulty?
Post by: clarence on November 12, 2009, 02:11:15 AM
Best is to send cr bk to Tan Chong to chk if it is under warranty.
Prob a  wire conection problem
Post by: RG on November 14, 2009, 07:34:58 AM
erm..juz a question i wanna ask..., if i brake hard..and and abs activated..the light will also come out issit?
since day 1 till now i brake hard till the ABS activate still no light, any issue wit that?
Post by: kanzo on November 14, 2009, 08:51:53 AM
 get your mechanic to check the speed sensor at your wheels. Unplug the connection n clean with contact cleaner. Maybe ur speed sensor dirty..
If not u can use Obd2 check the error code..another common problem is check ur ecu grounding wire maybe connection loose will affect the close loop signal so will show error for ABS..Just tighten the screw.. :)
Post by: kanzo on November 14, 2009, 09:05:55 AM
ah boy, next time ur car haf problem n u ask for help online , everyone tell u ur car horny n steam.. How would u feel?! If u wan to joke n bullshit around u can try www.boliaokinna.com
Post by: gary on November 28, 2009, 10:00:49 PM
might be brake pad worn out?
Post by: rontan on November 30, 2009, 10:29:26 PM
Lighted ABS lighted up means ABS braking will not be activated when required, EBD (Electronic Brake Distribute) is still working, so not a issues for normal soft braking. :thumbsup:
ABS Light up, mostly cause by electrical problem, DIY: chk fuse, remove and put it back to reset (make sure that the engine is OFF).
After washing with strong spray could cause some electrical short in sensor, water is good conductor.
