Author Topic: ABS kick in... ?  (Read 15920 times)
ABS kick in... ?
« on: January 29, 2010, 09:31:58 PM »
just now i slam on the brake when car is going about 30km/h +/-, i feel vibration on the pedal, quite mild but strong enuff for me to notice it. Also got a sound.
Is it ABS kick in? Anyone experience before?
Thanks...
Offline hwlee
  • Honda
Re: ABS kick in... ?
« Reply #1 on: January 29, 2010, 10:46:09 PM »
Did you check your front Brake pad? Brake Fluid? Brake System? I hope the ABS light didn't turn on (as malfunction) while you driving...  :D
Offline idiotboi89
« Reply #2 on: January 29, 2010, 11:18:49 PM »
Did it go DONG DONG DONG?
« Reply #3 on: January 30, 2010, 01:38:44 PM »
After that i continue driving, seems normal. The ABS light also never appear = no malfunction?
What is dong dong dong?
But i am curious, my speed only 30km/h, will activate ABS?
« Reply #4 on: January 30, 2010, 01:45:52 PM »
Very low speed also will activate, as long as the sensors detect your wheels locking. Normally happens when braking very hard on wet roads. I had it activate a few times when I brake over a road hump too.
Dong dong dong is the sound of the ABS kicking in. To me feels more like KOK KOK KOK. And brake pedal shudders violently.
Offline RG
« Reply #5 on: January 30, 2010, 06:58:20 PM »
i hear more like a loud TAK TAK TAK!!! n yeap ABS will activate at low speed also..
Offline CamholicX
  • Redline (6000 rpm)
« Reply #6 on: January 31, 2010, 09:56:15 AM »
not wise to use it often. As it will shorten yr break pump life
« Reply #7 on: January 31, 2010, 10:15:01 AM »
You can't choose when to use it bah. I'd rather it comes more often than not; it saves lives.
Offline nakshire
  • I'm a cute boy ok!
« Reply #8 on: January 31, 2010, 10:25:55 AM »
that means u everytime zam brake.. haha
Offline CamholicX
« Reply #9 on: January 31, 2010, 10:29:12 AM »
I realised our rear brake is drum ... omg..
« Reply #10 on: January 31, 2010, 11:34:18 AM »
I always coast till very near to stop then brake. Sometimes if the timing is right, the light will turn green and I don't have to stop!  ;D
Drum brakes are ok. Latio is pretty small, and most of the braking power comes from the front brakes anyway.
Offline hwlee
  • Honda
« Reply #11 on: January 31, 2010, 01:49:46 PM »
Latio if FF car... not 4WD car leh... back back use only when "foot brake" applied. The back brake  won't help you to brake while driving unless you change to 4wd..or plan to drift...
but, some of my friend, who drift... said drift is more nice is back brake is drum leh..lol
Offline CamholicX
« Reply #12 on: January 31, 2010, 02:22:40 PM »
HAr? But I tot when u depress brake , its always front and back break together .. but of cos more force exert to the front.
Offline hwlee
  • Honda
« Reply #13 on: January 31, 2010, 02:47:04 PM »
Simple to test...get a normal bicycle and ride it at fast speed.. then, during the high speed use only the front brake (cos bicycle is actually FR ride)..you see what happened :devil2:
Our car is FF... the transmission gear is at front. Rear wheel only dummy or when hand brake (foot brake?) is applied. That's why even your hand brake is still applied, your car still can move forward if you start your engine and depress the accelerator.
But, what good you change your rear brake to disc... is you can use the firm grab on the back (applied with hand brake fully)..then fully depress the accelerator pad..you can have the feel the smoke out from your front wheel...and the sound of your front tyres spinning on the ground... and you can drift with a FF car :devil2:
« Reply #14 on: January 31, 2010, 06:46:10 PM »
You sure depressing brakes only activate front brakes?
Not both?
Offline hwlee
  • Honda
« Reply #15 on: January 31, 2010, 07:20:30 PM »
Not both?
Both.  :bleh:
« Reply #16 on: February 01, 2010, 10:41:54 PM »
For my case there isn't violent shaking of the brake pedal. It is more like using OSIM product, massaging effect....  ;D
Btw i zam brake that day because i turn my head to look at another accident. :-p
« Reply #17 on: February 16, 2010, 07:58:46 AM »
chio boos & accidents are oways the main cause of drivers activatin their ABS... other than that latio is equipped with EBD = electronic brake distribution
Offline hwlee
  • Honda
« Reply #18 on: February 18, 2010, 12:06:26 PM »
Can use this product if you want..  :D
« Reply #19 on: February 18, 2010, 12:37:11 PM »
It looks fake as there's no brake calipers.
