Author Topic: Green "car Key" light on...  (Read 8720 times)
Offline idone2u
« on: February 22, 2010, 10:31:15 AM »
Recently I noticed that when I start my car... the green light on the car-key is on.. but it disappeared after about 10min or so...
Somehow I never see it before that last so long....
Is this normal or the battery is weak?
Re: Green "car Key" light on...
« Reply #1 on: February 22, 2010, 11:01:08 AM »
probably the battery is weak
have you changed the battery since you got the car?
try checking the arming/disarming distance using the remote control
if the distance is shorter than before, most likely it is time to change battery
Offline valeon
« Reply #2 on: February 22, 2010, 12:44:46 PM »
Time to change battery in the I-key liao. It still can last for a while, if continue ignore the green light, one day you will find you can't open the door ...only can use key to open door and start engine.
Offline car_man
« Reply #3 on: February 22, 2010, 08:56:34 PM »
Ya it's the batt as i recently also have that issue,but after i change the batt no more green light liao :yehyeh:
« Reply #4 on: February 28, 2010, 11:14:35 PM »
Confirmed. The flashing symptom is due to weak battery for i-key.
« Reply #5 on: March 01, 2010, 10:43:54 AM »
store a few batteries in your compartment and home. you never know when you need especially during urgent situation.
Offline priyana
« Reply #6 on: March 01, 2010, 12:01:53 PM »
haha.
I don't think there is an urgent situation that makes us not able to draw out the physical key and use it....
Offline shawnie
« Reply #7 on: March 04, 2010, 11:49:32 PM »
where can we get the batteries?
Glory Glory Man United, When the reds go marching on on on!
Offline ben5266
« Reply #8 on: March 05, 2010, 10:12:17 AM »
DIYs, stationary, or $1 shops at hdb neighborhood. Only $2 each.
« Reply #9 on: March 05, 2010, 11:51:58 AM »
sony cr2025 cheapest i got at $1.50 made in jepun
« Reply #10 on: March 05, 2010, 01:21:40 PM »
maxell CR2025 $1.20 Made in Japan
I have a spare one
