Author Topic: static shock  (Read 7115 times)
Offline fluxc
static shock
« on: March 12, 2010, 10:23:58 AM »
Hi bros, whenever i off my engine and get out of the car and the minute i close my car door, i get static shock! Anyway to slove this issue? Or why is it that theres always static shock?
Pioneer AVH-P4150DVD, Helix Cap33, Helix Dark Blue 2ch, Helix Dark Blue 4ch, Helix Dark Blue 62.1, Helix P203 Precision 3"mid, Dark Blue 62C, Helix Deep Blue 12" Subwoofer
Re: static shock
« Reply #1 on: March 12, 2010, 10:34:12 AM »
I guess
1) your skin too dry.
2) you rub the wrong stuff  :bleh: certain fabric will produce static if you rub them.
can try
1) hand lotion.
2) avoid fabric like fleece.
3) carbon fibre door handle protector... there was a GB long time ago.
4) when you close the door, push parts that are non conductor.
Offline nakshire
  • I'm a cute boy ok!
Re: static shock
« Reply #2 on: March 12, 2010, 10:42:05 AM »
Check for parts that are rubbing the ground when your car is moving. Some parts may be dangling, causing charge up during ur ride
Offline fluxc
Re: static shock
« Reply #3 on: March 12, 2010, 10:57:19 AM »
how to solve or fix this problem?
Re: static shock
« Reply #4 on: March 12, 2010, 04:52:11 PM »
Can try changing your footwear... I used to have this zapped when never I touch the door knob. After soe time i realise when i change my shoes to normal office shoe from clogged, no more zapped.
Re: static shock
« Reply #5 on: March 14, 2010, 07:09:53 PM »
friction from some parts during ride may produce static charge but hitting the ground actually discharge  it. Petrol tanker or similar turck have chains or some other object danging around tyre to discharge static.
Offline limcheemeng
Re: static shock
« Reply #6 on: March 15, 2010, 07:59:23 AM »
I encounter static everytime I get out of my car. What I do is that after I open my door, I will use my right arm (near the sleeve) to touch the door frame and it will discharge the static (you will hear the "Tiag" sound but you will not feel anything). After that it will be fine.
