Author Topic: headlight rubber  (Read 6616 times)
Offline nox
headlight rubber
« on: March 15, 2010, 04:35:58 PM »
hi, does anyone know where i can find the headlight rubber thing for latio? its the thing that you have to remove when changing bulb, mine tore abit and im quite concerned about whether it will leak water into the headlight housing. i checked with a few of the stockists but none sell the rubber only :( need to get the whole headlight :scared:
thanks!
Re: headlight rubber
« Reply #1 on: March 15, 2010, 07:42:05 PM »
How serious is the torn part? Ask around if there is any thing to mend it, but make sure the thing has certain heat resistance level....
Sounds weird to mend rubber, but if u can't buy the rubber alone and the whole headlight cost a bomb, u can consider my suggestion.
« Reply #2 on: March 15, 2010, 09:51:17 PM »
thanks!
why not try TC @ lok yang? There is the main spare part center at the new building
Offline vypez
    • need help with words?
« Reply #3 on: March 16, 2010, 12:13:56 PM »
silicon it bro. =]
Offline nox
« Reply #4 on: March 16, 2010, 02:11:24 PM »
ok i'll check out TC to see if they have, if not then maybe i can silicone it haha. is it still ok to use with a slightly torn rubber? water and all these won't get in right
Offline vypez
« Reply #5 on: March 16, 2010, 04:57:23 PM »
silicon shld work fine bro. =]
my guess is that the tear is on the outer lining.. and that part is not the "crucial" part.
