Author Topic: Front Lower Arm Bush - Replace  (Read 10650 times)
« on: March 29, 2010, 02:47:01 PM »
Anyone replace front lower arm bush before?
Any recommended workshop and what is the price of replacing it?
Offline zzyzx
Re: Front Lower Arm Bush - Replace
« Reply #1 on: March 29, 2010, 10:12:09 PM »
what for replace?  :confused1:
« Reply #2 on: March 29, 2010, 10:40:41 PM »
lower arm bush, that is link to your wheels, need to take out the rim then can see clearly.
Austosaver say can last more than 120k.  When you brake or depress, u heard tok tok sound...meaning arm bush start to give way..
« Reply #3 on: March 31, 2010, 11:49:35 AM »
I think I have to change mine too, some time got the Tok Tok sound when I slow down to make a turn. I recall some bro mention a ws at sing ming, have to search some old posting liao.
ok, I may try this ws, from
here
Quote
Ong Guan Choon Motor
#02-07
176, Sin Ming Autocare
Singapore 575721
Tel: 6453 4419
Boss: Lim Ah Beng (very experience  )
« Last Edit: March 31, 2010, 12:09:57 PM by Ying »
« Reply #4 on: March 31, 2010, 01:35:41 PM »
Whats the damage?
here
Offline zzyzx
« Reply #5 on: March 31, 2010, 05:27:46 PM »
i learnt something. tahnks!
« Reply #6 on: April 01, 2010, 04:00:38 PM »
intend to let them check this weekend.
Offline carowner
« Reply #7 on: April 09, 2010, 10:18:34 PM »
Anyone has a good workshop ro recommend for replacinf the lower arm?
Offline tchekchuan
« Reply #8 on: April 10, 2010, 12:56:42 AM »
is this an extra gadget ? or is this from stock? my ride got this tok tok sound whenever i depress brake or travel at a very very low speed (parking), i once change the steering coupling from TCM however this problem came back after a couple of months.
my ride is less than 2 yrs old, can i request TCM to change for me FOC?
Offline MadMatty
« Reply #9 on: April 11, 2010, 01:06:45 PM »
Sounds like (no pun intended) we have same problem. Complained to TCM when servicing and they changed the coupling thought that will solve the problem but the tok tok sound is there especially when cornering at very low speed. Sound like coming from below the steering wheel.. :confused1:
Offline tchekchuan
« Reply #10 on: April 11, 2010, 04:19:27 PM »
so is this the front lower arm bush or steering coupling?
does TCM replace front lower arm bush as well?
« Reply #11 on: June 07, 2010, 10:32:00 PM »
Finally replace my front lower arm today...
damage is as follows:
            Front lower arms Left + right =  $256.8
            Installation = $85.6
« Reply #12 on: June 08, 2010, 07:42:30 AM »
Problem solved?
« Reply #13 on: June 08, 2010, 04:33:14 PM »
Mind sharing where did you replace it?
« Reply #14 on: June 08, 2010, 04:50:53 PM »
I bought my own parts at Teck Guan
You can replace at Riverviewauto / autosaver.  Both of them had the same labour charge.
Offline vex
« Reply #15 on: June 30, 2010, 11:02:54 AM »
i bought the 2 lower arm bushing at autosavers for $120 or thereabout. replaced them together with the front shocks.
