Author Topic: Gear Stuck When Shifting From P  (Read 4836 times)
Offline Alson
« on: July 12, 2010, 12:08:41 AM »
Hi Guys,
I have recently experience gear stuck when trying to shift from P. I mean it really stuck and I have to try pushing it up and down to shift it to D.
Is it due to  CVT Oil require change or is it a gearbox problem? My latio is slightly more than 5 years old.
Please advise.
Offline JLHeng
Re: Gear Stuck When Shifting From P
« Reply #1 on: July 12, 2010, 07:15:21 AM »
Just to share. Got this problem before when my ride was less than 2 years, went back to TCM and got replaced the "ribbon cable". Happened again and went back TCM again but was told tighten the "ribbon cable" instead. Till now, so far so good.
Hope this helps.
« Reply #2 on: July 15, 2010, 09:40:26 PM »
Mine 4AT also stuck today even with brake depress fully, can't shift shift from P to D.
End up got to manually depress the shift lock to get to D. Damm.
« Reply #3 on: July 18, 2010, 08:39:51 PM »
Went to Autoaid on Sat and they found that the "brake switch" is faulty and have it replaced at $53.50
