Author Topic: Spark plug change @ 100k  (Read 15373 times)
Offline firestarter
  • i'm a firestarter, twisted firestarter
    • Come get your daily dump !!
« on: August 03, 2010, 06:07:59 PM »
anyone changed their spark plugs at 100k servicing?
i just did at autosaver and they quoted me $216 for 4 spark plugs + $60 labour .. got a shock that it cost so much !!! :crycry:
= insert signature here =
Mod the driver, before you mod the car ...
Offline kgleo
Re: Spark plug change @ 100k
« Reply #1 on: August 03, 2010, 09:43:51 PM »
For me its included in the NPMP 100K servicing.
Offline firestarter
« Reply #2 on: August 03, 2010, 09:51:19 PM »
wow .. how much did you pay for the NPMP package?
« Reply #3 on: August 03, 2010, 10:13:34 PM »
autoaid quoted me $140 for 4 plugs and labour but again, that was two mths back
« Reply #4 on: August 03, 2010, 10:14:45 PM »
http://www.mxtradings.com/NGK%20and%20others.htm
part: $110, labour is up to you to find a cheper source.
« Reply #5 on: August 03, 2010, 10:19:04 PM »
I think you are all referring to the OEM spark plug.  Nissan original spark plug is not that cheap. (think its Denso brand)
When i change last year still do not have the OEM.  So change at SOH tyre for the original spark plug for $160 including labour.
Offline swarovski latio
« Reply #6 on: August 04, 2010, 01:00:38 AM »
Dear Lations, i do have the original nissan spark plug for latio 4 sale per set at about $110 plus minus anyone keen pm me.
« Reply #7 on: August 04, 2010, 09:53:11 AM »
Original Denso FXE20HE11 for $110/set. Other spark can be as cheap as $30/set
Then again, say you renew at 100k mark and the new original spark can last another 100k, not many will drive till 200k right?
« Reply #8 on: August 04, 2010, 06:34:33 PM »
haha u may be wrong... my fren's kelisa clocked 180k within 3 yrs of ownership.
i say him mah, ur mileage can fight with taxi liao ah.
« Reply #9 on: August 04, 2010, 07:14:13 PM »
bro, did your friend do car servicing every alternate month? 18 servicing in 36 months  :blink:
« Reply #10 on: August 05, 2010, 07:15:21 PM »
ya sis tell u sumtin dunno if u believe anot but this fren of mine pours cooking oil into his tranny he says the wkshop mech in jb assures him nothin will happen to engine.. He has been doin dat eversince he hit 1OOk mileage.
Imagine how much he saves per servicin even if he were to change oil every 5k travelled.
« Reply #11 on: August 06, 2010, 09:41:11 AM »
Proton Boleh..  :D
The cooking oil is use as EO or ATF? They also add a bit of diesel as EO additive to clean the engine.
« Reply #12 on: August 06, 2010, 04:20:37 PM »
Can't remembered the cost, but I got it changed at 80k. Condition is really bad, so try to change it as early as possible.
Mine is original Nissan Sparkplug.
« Reply #13 on: August 06, 2010, 06:48:53 PM »
Proton Boleh..  :D
Perodua oso boleh ! ! !
his car is manual so no atf juz normal power steering fluid
its used as eo & he claimed that the car run as smooth as fully-syn eo but i sit his car i can feel his engine sounds rough...
his mileage juz hit 192890km as of 5/8/10 when i met him y'day nite.. Haha pity his car work day & nite for him like a slave..
Offline kungfu
« Reply #14 on: September 10, 2010, 09:47:28 AM »
Nissan using Denso Iridium.........usually $60 for 4 pcs. Any WS can do the change for you. Can do yrself.............but must be careful of things like cross thread the plugs etc..........
Offline m_k_tang
« Reply #15 on: September 10, 2010, 04:17:47 PM »
Bro,
Nissan Latio is using special spark plug model and is much more expensive and more difficult to install... If you can get $60 (or even $80) for 4 pieces of Latio spark plugs, a lot of Latio drivers (or even workshops) will queue up to buy from you.... Of course,I roughly know the cost of the Denso Iridium plugs for Latio in the market. From your nick & info (I reckon you are driving Toyota), your car's spark plugs are the common and cheaper ones (unless you are using Nology, Brisk or Pulstar plugs) in the market and simpler to do installation as compared to Nissan Latio...  ;)
« Reply #16 on: September 15, 2010, 01:43:20 PM »
NGK $28 per pcs DENSO iridium $30 per pcs exclude installation, got tis qoute frm a spare part shop at bt merah. Which brand of plug shd i change or shd i go for BRISK plugs since Nology doesn't produce for latio...
« Reply #17 on: September 19, 2010, 02:43:50 PM »
Im using original Sparkplug. Yes, it is not cheap at all but it is quite good already for an original plug.
During my 80k servicing, my sparkplug is already burnt out when I saw it. Try to change it before 100k if you can.  :D
I changed it at my friend affiliate workshop... So many things to take out in order to change the sparkplug.
« Reply #18 on: September 19, 2010, 03:25:03 PM »
Taxi mileage is way higher at 300,000™ km a year.
