Author Topic: Brakes Jammed  (Read 10192 times)
Offline motosung
Brakes Jammed
« on: October 03, 2010, 01:20:00 PM »
Was driving and noticed that my wheel was juddering alittle with the car pulling over to one side with slight loss off power
Pulled over and noticed my wheel was extremely hot so my suspicion of wheel weight flying off was ruled off
Went to TCM immediately and they told me my brakes were jammed. Luckily its not jammed in a very tight pull or i can't imagine what would have happened since i was driving in the expressway at that moment
They did a overhaul of my both front brakes and damage was around $170
Did not change brake pads since i just changed mine under NPNT around 8K KM ago
My car's 4.5 years old, millage 109K
Anyone else had similar problem?
« Last Edit: October 03, 2010, 02:04:05 PM by motosung »
Re: Brakes Jammed
« Reply #1 on: October 04, 2010, 11:02:35 AM »
Mine did but on the left hand side. replace the oil ring assembly at AS
Offline sunnyong
Re: Brakes Jammed
« Reply #2 on: October 05, 2010, 09:01:44 AM »
hmm.. I always feel that something is amiss when i drive above 60km/h.. bro.. how to check beside sending to TCM??
My ride also very noisy when i start.. (Alternator or fan belt? how to know which one?). start w/o aircon.. got sound.. on aircon.. sound is LOUDER!! perhaps BOTH? :scared:
EVERY servicing @TCM always got change this and that.. always say this need to change.. that need to change.. how to know what are the necessary things to change?? anyone can recommend which hospital and doctor to go for 'FULL BODY CHECKUP'??
Re: Brakes Jammed
« Reply #3 on: October 05, 2010, 03:25:20 PM »
Try Autosaver or Autoaid
Offline Gone with the wind
Re: Brakes Jammed
« Reply #4 on: October 06, 2010, 08:08:36 PM »
Motosung, you mentioned you just changed your break pad not too long ago at TCM.  Did it occur to you that TCM might not do a proper job, like they did not clean off all the break dust, or install the break pad or whatever mechanism properly that it caused it to jam?  Remember you had did 100k without a single problem, and normally break calippers would not cause problem, because this is the most important portion of a car.
You should have questioned TCM and asked them to explain how and why it jammed after their service.
Just my 2 cents thought.
Offline hwlee
  • Honda
Re: Brakes Jammed
« Reply #5 on: October 06, 2010, 08:13:57 PM »
Just go and change the alternator belt. it cost under SGD50 for the belt then you get a workshop to help you replace it with new. The sound will gone. :)
Offline hwlee
  • Honda
Re: Brakes Jammed
« Reply #6 on: October 06, 2010, 08:19:58 PM »
Due to safety come first, if really the brake pump jammed, it is seriously spoiled and you need it to be replaced rather than repair. Brake jammed will make your car moving like brake is pressed cos brake will not release.
i change my front brake pad myself...never need to clean anything leh... touch wood. LOL
Re: Brakes Jammed
« Reply #7 on: October 07, 2010, 01:52:07 AM »
You can also try Nissan specialist Riverview Auto.
Offline motosung
Re: Brakes Jammed
« Reply #8 on: October 11, 2010, 04:58:10 PM »
I've not questioned them, and it seems too late now?
I don't know what other problems my Latio is gonna have. I thought i've been through all of them having it for 4.5 years already. Didn't expect the brakes to have any problems especially from a made-in-Jap car like Nissan. No recall needed to solve the problem? To me brakes jamming up is a serious problem
I'm having this issue here fellow Latio drivers please share if you have the same experience. It still exists even after they did the overhaul on my brake system. If i were to jam my brakes really hard from lets say 80 or 100 km/h to a stand still say at a traffic light stop. When the traffic light turns green and i step on the accelerator to move on, it seems like the car has a loss of power for afew seconds. This always happens to me after i jam the brakes real hard from high speed. It's as if the brake pads are stuck to the brake disc or the car for some mad reason doesn't want to accelerate as normal. RPM will be going up but acceleration would be very slow and it takes about 4-6 seconds for it to "recover" to accelerate normally again. I suspect the brakes and surprisingly the "problem" is still there even after the overhaul. Probably i need to get back to TCM on this problem when i go for my 110K servicing next month
Re: Brakes Jammed
« Reply #9 on: October 12, 2010, 09:56:16 AM »
a good brake system is a must but try to reduce those jam brake from high speed thing. Let go your pedal at the right time and keep a safe distance.
The 4-6 sec is for you to think are you going too fast and too close.
Offline motosung
Re: Brakes Jammed
« Reply #10 on: October 13, 2010, 01:09:01 AM »
I don't come across a situation where i need to jam my brakes hard when i'm driving normally on the road
I only press that hard occasionally when i'm driving enthusiastically on an empty road just having some "fun"
If i slowly release towards the very end, which would result in a smoother stop even though i pressed very hard initially, i wouldn't have this problem
My point is i've never experienced this on any other car i've driven before except this Latio
Re: Brakes Jammed
« Reply #11 on: October 13, 2010, 11:05:51 AM »
go to another workshop mentioned by some bro here for a check. we can say maybe is the tube, the oil, the pump or the spring etc but you still need a mechanic to verify the cause of the problem. Since TCM can't solve the problem you should try other branch of TCM workshop or just do your servicing outside.
This may not be the cause but since you like to have some fun occasionally, you should consider upgrade your pad to higher temperature grade type instead of changing back to stock pad at TCM.  A bro is selling his Run&Stop curve slot rotor + nano pad at a good price now.
