Author Topic: Suspension and shock absorber  (Read 7585 times)
Offline speedster
« on: November 08, 2010, 08:56:03 PM »
Hi all fellow lation, i am a new car owner and just want to check with all of you if there is anyway to know the condition of the shock absorber. What i am meaning is the sound made when going over hump or height of the suspension. Noticed my rear suspension is make a "thump" sound when going over hump unless i bring it to a complete stop and roll over at a super low speed. I also noticed recently my rear looks more lowered then before and the gap between the tyre and wheel arch for my rear is really close. Thanks all for your advised.  :confused1:
Offline machim
Re: Suspension and shock absorber
« Reply #1 on: November 09, 2010, 12:20:15 AM »
I suggest u bring to Tan Chong to check as yours is under warranty but think only Ubi has the cap to do the test.
Offline speedster
« Reply #2 on: November 27, 2010, 10:57:19 AM »
no more warranty with tan chong. so am reluctant to go back. the checking cost will be high.
« Reply #3 on: November 27, 2010, 12:06:13 PM »
replacing the coil over stuff are not ex can even look for a pair in scrap yard
Offline speedster
« Reply #4 on: November 28, 2010, 12:48:11 AM »
any scrap yard to recommend?  :D
Offline swarovski latio
« Reply #5 on: November 28, 2010, 08:36:37 PM »
change to kyb shock ... solve the issue... because if u get from scrap yard for headlight or other stuffs is o.k but suspension i see no point because u dunno how long was been use
« Reply #6 on: November 29, 2010, 12:05:33 AM »
Bro, you have lobang for the KYB shocks? Front and Rear how much all together including installation? Need to change mine too.
Offline DL70
  • Car Color: red
« Reply #7 on: November 29, 2010, 12:22:14 PM »
can send it to any auto workshop to check and replace. about $400 per set.
« Reply #8 on: November 29, 2010, 02:09:22 PM »
You mean all 4 pieces, including labour? $400.00?
Offline DL70
  • Car Color: red
« Reply #9 on: November 29, 2010, 03:28:03 PM »
all 4 pieces think will cost you near to $1000. per set of front or rear only
« Reply #10 on: November 30, 2010, 01:38:55 AM »
front and rear with labour should be around 550... using kyb from japan... i still have 4 set front n 3 set rear....
