Author Topic: Hard jerking when engage to reverse.  (Read 12809 times)
Offline JazONtheMOVE
« on: December 30, 2010, 03:18:32 PM »
This happen for some time now, I'm having this problem when engaging to reverse gear. It will start to engage at after a few second like almost 4 second with a gassy sound then a hard jerk. S.A. say nothing to be alarm after the CVT and tuning done it will be ok again. So now it have been like 2 week after servicing at 120k it started again.... Any lation have this exprience and how to retified. :crycry: :crycry:
Offline edwardtkh
Re: Hard jerking when engage to reverse.
« Reply #1 on: January 01, 2011, 09:49:44 PM »
gassy sound and 4 secs (seems long!) of delayed gear engagement sounds worrying, better check with TC again. hopefully its not the gearbox faulty...   :weep: :weep:
« Reply #2 on: January 04, 2011, 01:47:10 PM »
Thanks Bro
Will Continue to check with TCM, just wanting to know any others have this kind of exprience....
Offline cm2109
« Reply #3 on: June 25, 2011, 10:48:26 PM »
Thanks Bro
Recently encounter same experience on my Yr2006 ride, 90,000km.
Hi JazONtheMOVE and gurus,
Appreciate and advise from anyone that have enconter and get solve this. Thanks a million
Offline cm2109
« Reply #4 on: July 03, 2011, 01:39:08 PM »
Anyone have experience and rectify before can advise. Thanks :ohmy:
« Reply #5 on: July 04, 2011, 01:57:14 PM »
This problem could lead to the reverse gear hydraulic gear engage system, It will not damage the cvt box cause it a separate system but the cost involve also could reach up to $3k..... if the cvt box could cost around $12k. What i do just ignore. Talk to S.E. but thay said its fine. So for now just take it as if nothing happen.
Offline cm2109
« Reply #6 on: July 05, 2011, 09:30:28 PM »
Thanks Bros.
Keep our finger cross, hopefully the jerking does not goes worst.
I felt something like clutch like mechanism inside when engaging reverse, did not contact fully at first.
When i engage D from N and to R or vice versa. There is this "tak tak" sound coming from below the car. I can heard this at a quiet basement carpark.
One workshop told me highly suspected is the CVT gearbox. :(
« Reply #7 on: July 06, 2011, 08:17:52 AM »
If you still under warranty then get it done with TMC......CVT is a something u don't want to get involve with.....$$$$ A second hand CVT from japan of only 3 years is about $6k - $7k. Hope nothing bad will happen. I'm changing my ride soon so I will depart with my baby by end of Sept. and dekitting my ride  :crycry: :crycry:
Offline kt
  • Car Color: Amethyst Grey
« Reply #8 on: July 07, 2011, 03:39:54 PM »
I also experience something similar...but for me the hard jerking only comes when I'm turning my steering. If steering is straight everything's fine. So far my wife experienced it once, and me once....
Offline cm2109
« Reply #9 on: July 07, 2011, 10:42:29 PM »
Probably that is different, your steering mechanism may need to check. If under warranty do go back and get it done.
Mine ride is out of warranty 1.5 yr back. Have to stick to my ride, if serious enough have to weight the cost and rectify it.
« Reply #10 on: July 08, 2011, 07:57:16 AM »
likely the reverse gear is spolit. get it check with TMC if its still under warranty.. :thumbsup:
Offline kendrick1430
  • Car Color: red
« Reply #11 on: October 18, 2011, 11:09:03 AM »
i am also having this problem.
is yours solved?
Offline yapsf
« Reply #12 on: May 05, 2012, 10:14:24 PM »
I'm facing the same issue. Any resolution to this?
Offline Deva Rajan.K
  • Car Color: champagne gold
« Reply #13 on: May 08, 2012, 02:10:03 PM »
having same problem.Brought to tan chong this morning,they checked and advised me to service the gear box.
estimated cost 3K to 3.5K and takes at least seven working days !!
« Reply #14 on: May 08, 2012, 04:20:03 PM »
can try autoaid, autosavers, bro kelvin for 2nd opinion and quote, most properly will be cheaper than TCM.
« Reply #15 on: May 08, 2012, 04:35:41 PM »
Thanks alot !!!
