Author Topic: spark plug  (Read 27600 times)
Offline rocket
spark plug
« on: January 25, 2011, 11:29:14 PM »
just replaced my stock spark plug today ( milage 70K), to my surprised, the model is DENSO FXE20HE11, Iridium.
Just wondering the Iridium one can last 100k?
Offline sukoo
Re: spark plug
« Reply #1 on: January 26, 2011, 01:05:30 AM »
bro is it nissan packing?
Re: spark plug
« Reply #2 on: January 26, 2011, 08:02:31 AM »
It suppose to last till 100K km.....changed mine at 100K km......
Offline rocket
Re: spark plug
« Reply #3 on: January 26, 2011, 10:14:07 AM »
no Nissan logo , just " Denso iridium" printed on it
Re: spark plug
« Reply #4 on: January 26, 2011, 11:51:28 AM »
The Denso spark is the original factory setting. On manual it says you can use FXE22HE11 or FXE16HE11 to replace the FXE20HE11. I just use back the same original part, $110  + $30 labour.
Re: spark plug
« Reply #5 on: January 28, 2011, 03:30:43 PM »
I had it changed at 80K. Got a shock when I saw the spark plug. =)
Offline clsdch
Re: spark plug
« Reply #6 on: January 30, 2011, 05:32:52 PM »
Could you explain why you got a shock, when you see the spark plug? Any reason why you change the spark plug before 100K?
Offline freak
Re: spark plug
« Reply #7 on: January 31, 2011, 11:43:36 AM »
HI could you let me know where to bought the plugs and where did you get them replaced?
Sounds cheap. or is it all workshops around that price for labour?
thanks
Offline wahlin
Re: spark plug
« Reply #8 on: February 07, 2011, 09:29:11 AM »
I called TCM 2 weeks ago and was quoted $160 for 4 spark plugs plus another $120 for labour.  Your price is attrative, care to share.
I got some engine vibration at idling and also at 1800rpm.  When to 2 workshops and still cannot get the problem solve. Tried Caltex 98, carbon clean ..etc also the same.  Hope by changing spark plugs will solve the problem.
Btw my mileage is 87K, 5 years old Latio.
Re: spark plug
« Reply #9 on: February 08, 2011, 12:43:57 PM »
I found it from this forum, just changed spark plug and EO not too long ago.
http://www.mxtradings.com/
call them before you go.
I should had done the  throttle body cleaning first (they can do but they don't have the computer to tune your engine) then change spark plug plus EO change. When they remove the cover, I can see thick sticky slug on the internal wall. If I have sone the throttle body cleaning then can inspect how effective is the cleaning process. If not so clean still can spay some solvent on it.
If you use Vpost or travel to US then can buy from there ~USD50+ per set. Labour cost is S$30 for latio.
Re: spark plug
« Reply #10 on: February 10, 2011, 12:34:26 PM »
Shock as in.. time to change it. It's all burnt out.
It is a smooth drive after changing it. =)
Re: spark plug
« Reply #11 on: February 10, 2011, 02:14:10 PM »
What exactly does the electrode look like? Do you mean that the electrode is gone when you mentioned burnt out? Quite scarry when you used the term burned out. I used mine till about 95K km and the plug was still OK. FC is still about 12.75km/L after changing.
Re: spark plug
« Reply #12 on: February 12, 2011, 12:00:03 AM »
hi there, replacement of spark plug for all latio are recomended at 100 000km.no need to change them before that miledge. :smile:
Offline Latio38
Re: spark plug
« Reply #13 on: February 13, 2011, 01:02:15 PM »
Newbie here. Just got my 4 pcs of original spark plug (FXE20HE11) for latio (with Nissan packing) @ S$25/pc m I kana kuto already?
Re: spark plug
« Reply #14 on: February 13, 2011, 04:38:27 PM »
No, $100 per set is even better.
Re: spark plug
« Reply #15 on: February 14, 2011, 11:20:07 PM »
any one know how much is the cost for labour and parts for replacement of spark plug :confused1:
Offline wahlin
Re: spark plug
« Reply #16 on: February 15, 2011, 01:33:23 PM »
The cheapest so far is $130. $100 for 4 pcs of denso spark plugs plus $30 labour.
« Last Edit: February 15, 2011, 04:57:10 PM by wahlin »
Offline verylazy
  • Car Color: gold
Re: spark plug
« Reply #17 on: February 15, 2011, 09:01:30 PM »
Pls share where to change at $130. Gd lobang must share share.
Re: spark plug
« Reply #18 on: February 17, 2011, 07:10:54 AM »
check out Sung Beng Auto.  They charge $108 for change of spark plugs.  If you are doing servicing with them, there is no additional labour charge incurred for spark plug.
Offline rocket
Re: spark plug
« Reply #19 on: February 17, 2011, 09:08:33 AM »
Your engine vibration issue resolved after spark plug change?
