Author Topic: spark plug  (Read 23135 times)
Re: spark plug
« Reply #20 on: February 17, 2011, 06:41:44 PM »
try changing ur engine mountings.it will help.
Offline wahlin
Re: spark plug
« Reply #21 on: March 04, 2011, 01:37:54 PM »
Your engine vibration issue resolved after spark plug change?
Too busy during the CNY no time to change but will probably do throttle body cleaning first.
Offline wahlin
Re: spark plug
« Reply #22 on: March 04, 2011, 01:43:28 PM »
I tot of that too but my engine mountings are only 9 months old.
Offline wahlin
Re: spark plug
« Reply #23 on: March 04, 2011, 01:47:02 PM »
Pls share where to change at $130. Gd lobang must share share.
No wonder you got sure a nickname.  Refer post 10 above.
Offline froggiee
Re: spark plug
« Reply #24 on: February 03, 2012, 03:00:31 PM »
Any Lobang to replace denso fxe20he11 spark plug? Mine reach 100K
Re: spark plug
« Reply #25 on: February 03, 2012, 10:44:04 PM »
bro,can find me.i got lobang leh.PM me if want.
Offline froggiee
Re: spark plug
« Reply #26 on: February 04, 2012, 02:10:35 PM »
Err I PM you but yr inbox is full.
Re: spark plug
« Reply #27 on: February 05, 2012, 12:29:03 AM »
bro,very sorry,inbox very hot leh...can try again..........thanks ;D
Offline edwin
  • Car Color: Silver
Re: spark plug for Latio Premium
« Reply #28 on: February 06, 2012, 10:51:15 PM »
I found it from this forum, just changed spark plug and EO not too long ago.
http://www.mxtradings.com/
call them before you go.
I should had done the  throttle body cleaning first (they can do but they don't have the computer to tune your engine) then change spark plug plus EO change. When they remove the cover, I can see thick sticky slug on the internal wall. If I have sone the throttle body cleaning then can inspect how effective is the cleaning process. If not so clean still can spay some solvent on it.
If you use Vpost or travel to US then can buy from there ~USD50+ per set. Labour cost is S$30 for latio.
Hi Ying,
Please share with me which website should I visit to buy Denso plugs via Vpost.
Offline ahjie
  • Car Color: blue
Re: spark plug
« Reply #29 on: February 16, 2012, 03:12:33 PM »
I just bought the denso iridium spark plugs from mx trading yesterday @ $110.
Re: spark plug
« Reply #30 on: February 16, 2012, 05:06:04 PM »
brother can take look at the plugs,is it really DENSO IRIDIUM or is it NGK?outside u buy the plug it's packed in NISSAN box but the inside is NGK.original nissan plugs is DENSO.
 :yehyeh: :yehyeh: :yehyeh:
Offline ahjie
  • Car Color: blue
Re: spark plug
« Reply #31 on: February 16, 2012, 10:40:30 PM »
It's in a Denso box with 4 individually packed spark plugs inside. The words Denso iridium FXE20HE11 are indicated on both the outer and inner boxes, as well as on the spark plugs itself  :thumbsup:
