Author Topic: How to remove Door panel  (Read 12892 times)
Offline CamholicX
  • Redline (6000 rpm)
« on: February 06, 2011, 11:18:55 PM »
Anyone can advice me? I need to DIY soundproof
Re: How to remove Door panel
« Reply #1 on: February 07, 2011, 03:50:53 AM »
1) gently remove the plastic C shaped-clip from door open handle with a flat head screw driver
2) remove the door cup (where the power window switch & where u pull the door to close) is located by flat head screw driver
3) use philip head screw driver to unscrew 2 screws from the door panel (where the door cup is previously located)
4) use your hand to pull the door panel starting from base edge then move upwards along the edge
to install back, do vice versa.....
Happy DIYing.......remember to do steps 1 & 2 gently as these are plastic parts with hook and they break easily.....
Offline CamholicX
« Reply #2 on: February 07, 2011, 11:33:42 PM »
wow.. tried but still cant. Can I meet u up and u teach me pls ?
« Reply #3 on: February 08, 2011, 08:45:24 AM »
sure....but i am only available from 7pm onwards on weekdays @ AMK and anytime from Sat 2pm onwards for weekends @ Punggol....
U plan then let me know.....so we can try to arrange a suitable schedule....
Offline Tomyamboi
  • Car Color: GOne with the wind
« Reply #4 on: February 08, 2011, 10:47:44 AM »
 bro  after u done with no.2 no.3 . u need use  to  force open it...  :bleh:
DOne tat  Do tat  now Finish tat
« Reply #5 on: February 08, 2011, 11:10:43 AM »
yah...maybe my instructions was not clear enough....for Step 4, need to use some force to pull open the panel....
Offline CamholicX
« Reply #6 on: February 08, 2011, 01:31:22 PM »
I am stuck at step 2
« Reply #7 on: February 08, 2011, 02:53:26 PM »
use the flat head screwdriver & insert into the edge of the door holder and just prised upwards....then remove the wire connector....
Offline CamholicX
« Reply #8 on: February 09, 2011, 12:19:32 PM »
Noted. Let me try again.
Offline tweakmax2
« Reply #9 on: August 14, 2011, 03:47:59 PM »
I still got problem taking it kit
« Reply #10 on: August 14, 2011, 06:16:13 PM »
step 2 ,you can use ur hands to pull upwards.i did that before,but need abit of force.
Offline CamholicX
« Reply #11 on: August 14, 2011, 09:41:12 PM »
i cant take out the c clip and the window controller. Anyway after taking out the silver c clip, is there any more clip underneath to be remove?
So the door panel only have clip at the bottom to hold it ?
« Reply #12 on: August 14, 2011, 10:40:02 PM »
yap,no more clip besides the c clip that cover the door open handle.
Offline CamholicX
« Reply #13 on: August 14, 2011, 11:44:59 PM »
bro kelvin.. where u stay... tot of asking u to show me how to open
Offline Tomyamboi
« Reply #14 on: August 14, 2011, 11:53:45 PM »
bro if u stay ard  tamp side .. i can show u how to remove the door panel ;D
« Reply #15 on: August 15, 2011, 06:09:59 PM »
jurong east ,bro.can find me anytime.
