Author Topic: Serious Help Needed with my latio FC  (Read 22627 times)
Offline spencer
  • Car Color: White
« on: February 17, 2011, 11:19:28 PM »
Hi fellow Lations,
really need some help here. My Latio (4AT) just cross 50,000 mark, and my FC is terrible. full tank till brim, fuel light shown today when I only clock 328km. if just based on 35L, with 10L as reserve when light show up, it's 9.3L/KM.
This is extremely bad. I had just bought this car and didn't expect this to happen cos my fren's latio (4AT) can do 14-15kM/L.
I generally do 60% HW/40% urban.
Please help me with it...
what can I do... I did a search but dun find anyone in a similar condition...most slightly better...
Offline ivansyl
Re: Serious Help Needed with my latio FC
« Reply #1 on: February 17, 2011, 11:55:45 PM »
mine clocks 400km then light shows up with 16inch wheels. haiz.
Offline crusty69
« Reply #2 on: February 18, 2011, 12:50:42 AM »
maybe can try changing/renewing yr cvt or atf fluid ,... after that yr spark plugs . It helped with my fc before. Then maybe can go  for throttle body clean ( take out throttle body and scrub using oil )
Offline eagleyes647
  • eagle eyes
« Reply #3 on: February 18, 2011, 01:19:01 AM »
yeah crusty is right, do try throttle body cleaning it really helps. we have orady 4 cars doing the cleaning net sunday 27 Feb @ 11am onwards, at Toh Stop R Pte Ltd, 48 toh guan road east, #01-115. Damage is only $50, if go back TCM is $160   :thumbsup:
Offline kt
  • Car Color: Amethyst Grey
« Reply #4 on: February 18, 2011, 08:29:25 AM »
Bro u got their contact no? Is there a GB going on for the throttle body cleaning now?
Offline d.titan
« Reply #5 on: February 18, 2011, 09:03:31 AM »
do the basic
enigine oil & filter change,
engine air filter check or change
spark plug check or change
ATF oil change
check tire & pressure (pressure higher will help), replace tyre if necessary
try not to switch aircon to the lowest temp, somewhere u are comfortable with.
mine's at 25 degree
drive at normal speed, do not sprint or accelrate unnecessary
clear yr boot of things u do not need
lose some weight if yr r too heavy...(heehehe...jus kidding)
...more if i think any...
lastly, if still can not, bring to Tan Chong for
checks...maybe filter injector dirty, air & fuel ratio NG...etc
Not necessary to repair at TC, jus check and pay some $
« Reply #6 on: February 18, 2011, 09:15:03 AM »
Have you checked your tire pressure? Having 240kpa for all four wheels.
Offline spencer
  • Car Color: White
« Reply #7 on: February 18, 2011, 09:17:37 AM »
I'm more of a light-footer. Generally crusing at 2-2.4k rpm...
Mine's on a 16 inch as well...previous owner use cheena tire... what would be the optimum tire pressure anyone?
Offline hwlee
  • Honda
« Reply #8 on: February 18, 2011, 09:34:17 AM »
try to cruise 2K rpm or below..
like what previous bros saids...change to EO to Full Synz, change back to Denso Spark Plug, maintain Tyre Pressure (230 front, 210 rear), clean up unnecessary items from your rear boot (especially those heavy item) and do the throttle body cleaning..
Default tires pressure for latio is 230 front and 210 rear... if you don't want your tires get "pregnant", try to stick with this.
Offline alghojo
« Reply #9 on: February 18, 2011, 09:56:21 AM »
My 2 yrs latio sport 4AT FC also decreasing. Use to get 14-15km/l now only 11+.
Change EO to amsoil, no difference. Probably try the throttle cleaning.
« Reply #10 on: February 18, 2011, 12:36:37 PM »
with 40%CT >> u can get 420km with full tank .. minimum ..
like that the others suggest, try throttle cleaning and tire pressure.. these 2 will have big changes to your FC
personally>> i use 260 for front tires and 240 for back..
Offline crusty69
« Reply #11 on: February 18, 2011, 01:10:26 PM »
AS for tyre pressure, I use 80% of max tyre pressure located at side wall ,.. so far,, ok  ;)
Offline Roy
« Reply #12 on: February 18, 2011, 02:47:07 PM »
clear the boots & try to cruise at 2k rpm abt 80 to 90 km/h u will see the mileage after 1 week.
« Reply #13 on: February 18, 2011, 05:33:02 PM »
about the throttle body cleaning...
Do you disconnect the throttle body to clean just the throttle body or using the "spray & rev" method to clean the throttle body, the air manifold and the rest of it.
can share where you did it and your review?
« Reply #14 on: February 18, 2011, 05:47:36 PM »
Did my TB cleaning at autoaid.  They acutally dismantle out and clean inside with soemthing that smell like kerosene.
After that they do a consult tuning which is important in case your RPM goes too idle after the cleaning.
« Reply #15 on: February 18, 2011, 07:56:56 PM »
What is consult tuning ? Is it same like air/fuel tuning and adjustment ? What the damage ?  Thanks. ;)
« Reply #16 on: February 19, 2011, 07:18:25 AM »
something like that.  It is the same as everytime after you do your service in TCM, they also do consult tuning.
There is no extra charge for consult tuning, it is already covered in the TB cleaning.
« Reply #17 on: February 19, 2011, 09:55:41 AM »
the Throttle cleaning i did with eagleye647 @ pitstop R, the guy will dismantle everything to wash so its quite thorough one.  then he will do consult tuning to fine tune all the basic settings of ur engines
Last year, he did a re-tune and my idling rpm fall back to 900rpm and the response of the car is much better
can give it a try if u have not done any cleaning before.
« Reply #18 on: February 19, 2011, 01:44:11 PM »
Same as autoaid.  I believed Pitstop R and autoaid are side by side.  Maybe they share the same resources in Throttle body cleaning....
Offline spencer
  • Car Color: White
« Reply #19 on: February 19, 2011, 03:31:30 PM »
Robtan99 how much was the tb cleaning and consult tuning cost at auto aid/pitstop r.?
« Last Edit: February 19, 2011, 03:33:54 PM by spencer »
