Author Topic: Serious Help Needed with my latio FC  (Read 18703 times)
Re: Serious Help Needed with my latio FC
« Reply #20 on: February 19, 2011, 03:55:09 PM »
i think they are same price based on the posting above.  I did twice at autoaid which cost 50 + 7% GST.
Robtan99 how much was the tb cleaning and consult tuning cost at auto aid/pitstop r.?
Offline alghojo
« Reply #21 on: February 20, 2011, 09:16:10 AM »
How long it takes to complete the TB?
Offline quirky
« Reply #22 on: February 22, 2011, 11:49:19 AM »
Don't you find the ride very hard if you pump pressure of 260/240?
Did you change your suspension?
with 40%CT >> u can get 420km with full tank .. minimum ..
like that the others suggest, try throttle cleaning and tire pressure.. these 2 will have big changes to your FC
personally>> i use 260 for front tires and 240 for back..
« Reply #23 on: March 17, 2011, 08:34:02 PM »
Think need to go for TB cleaning, recently step on accelerator like no immediate response, after maybe 2 sec the the power and rev then come in.  :unsure:
Offline kt
  • Car Color: Amethyst Grey
« Reply #24 on: July 19, 2011, 09:33:23 AM »
Just to check with the bros here who went for throttle body cleaning. After doing it, did your RPM shoot up to 2500 when starting your engine? Mine did and I went to my workshop and my mechanic had to reset my ECU. He said this was a common problem after throttle body cleaning. So would like to check with bros here whether anyone experienced the same issue as mine?
Offline vinzlee
  • Look ahead of situation
  • Car Color: Silver
« Reply #25 on: July 19, 2011, 11:59:39 AM »
Mine. Morning startup is 1.5k. AT model. Should ask SE at TCM whether any adjustment needed.
« Reply #26 on: July 19, 2011, 08:58:48 PM »
Why reset ECU after TB cleaning ? Thought some bros here mentioned performed consult tuning after cleaning.
Offline kt
« Reply #27 on: July 20, 2011, 09:48:06 AM »
I think mine didn't.  :unsure: :unsure:Coz my RPM became crazy after TB cleaning, as a result my already bad FC became worse  :( :( :(and it only became normal after resetting my ECU...
« Reply #28 on: July 20, 2011, 08:33:04 PM »
So after resetting your ECU, your FC became normal as in before cleaning or better ?  :smile:
Offline kt
« Reply #29 on: July 21, 2011, 08:28:23 AM »
It became the same before I did the cleaning. But could feel the car's more responsive...
Offline ooi_eddie
  • Car Color: White
« Reply #30 on: July 22, 2011, 06:45:25 PM »
Traffic jam also will affect on FC. Try to void traffic jam or heavy traffic road ;D
