Author Topic: Please help - AirCon Not Cold  (Read 39397 times)
Offline drixsome
Re: Please help - AirCon Not Cold
« Reply #20 on: June 13, 2011, 10:21:51 PM »
i think same problem as mine. better bring back to TCM. they got promo going on, i just got my ******** cooling coil replaced. $504 incl GST!
Offline magic1980
« Reply #21 on: June 15, 2011, 07:17:47 PM »
Hi. I was in Genting when my Aircon failed me. It suddenly don't blow cold air anymore.
Some details:
1) Aircon blowing but hot air.
2) press a/c button got the tuck tuck sound, meaning the switching is ok right
3) day or night, always hot air
4) at KL outskirt, got it inspected at a local workshop. Boss say got gas, likely compressor spoilt. Is it true?
Do u have any workshop to recommend???
I got mine changed at a regular workshop.
$550 change compressor, dryer, top up gas and labour. Reasonable right?
« Reply #22 on: June 16, 2011, 08:28:07 AM »
Change compressor so cheap only? Changed mine at TC BT for $1.3K.....
Offline 1258
« Reply #23 on: June 17, 2011, 12:36:38 PM »
Recently I have just changed my coil @ TC lucky still under warranty but have to pay 4 the gas :confused1: 1 yr ago I have went buck TC to change sensor. Now I only need to set my air con @ 27 instead of 25 & it very cold.
It seems like now a day air con don't last long so if anything not correct just go buck to TC B 4 ur W is over. :devil2:
Offline just
« Reply #24 on: June 22, 2011, 08:55:16 PM »
my aircon suddenly failed also .. day and night time also not cool. hopefully it not compressor spoilt. will go down this fri to check up. ..
Offline Latio_33
  • Car Color: Grey
« Reply #25 on: June 23, 2011, 07:18:52 PM »
Wow very resaonable..so which workshop..can share? :thumbsup:
« Reply #26 on: June 24, 2011, 08:33:07 AM »
try autoaid or autosaver, they are usually cheaper than TCM
Offline just
« Reply #27 on: June 24, 2011, 09:21:55 AM »
Went to TC to check my aircon, was told it's cooling coil leak, need to change cooling coil and thermo sensor ....the SA told me it's often fault after >100k .....if last year it will cost me $1000 plus to change now is $500 plus......  Anyone having this problem after >100k?
« Reply #28 on: June 24, 2011, 10:49:41 AM »
My coolin coil up e lorry when mileage was only 60k+
got it replaced at 1 of the wkshop at autobay dat specialised in a/c
Totl damage was $430 includes filter, gas & oil
Offline just
« Reply #29 on: June 24, 2011, 10:10:40 PM »
Understood TC will charge higher, since I'm on the NPMP so go back to them to check aircon and other thing.
Offline magic1980
« Reply #30 on: June 25, 2011, 08:31:07 AM »
It is at sungei kadut. Owner is simon.  I forget the name of shop. If u really keen i need to drive over check for u. Let me know if u keen.
Offline kenny59
  • C'mOm Let'S Play...
« Reply #31 on: June 28, 2011, 12:54:23 PM »
Hi all...My latio is  4 years old,just had my cooling coil replace which cost me $400 only at ubi area.Half a day is all it takes and will service all air-con filter or even change them and check everything for u.
Offline kt
  • Car Color: Amethyst Grey
« Reply #32 on: June 28, 2011, 03:49:59 PM »
Bro can let us know the name and address of the workshop? BTW my cooling coil also up lorry last month. Went to TC and they quoted me $550 for replacement of the cooling coil. I remember one of the bros here posted that it costs him $400 plus in Apr, so i question them abt it and they told me that was April's special price  :glare: So May going to cost $500 plus, then June going to cost $600 plus and December going to cost 1.2k?? :mad: :mad: Anyway I told them not to do anything and I drove to Autoaid and was charged ard $550, including cleaning of throttle.
Offline SpeedLimit
« Reply #33 on: July 03, 2011, 04:41:08 PM »
Hi bro,
Able to share the contact for the workshop.
Thanks.
« Reply #34 on: July 03, 2011, 11:25:38 PM »
Members, would be good if you can list the place the got your car done when the price is better that most of the shops that are mentioned so that others can benefit without having to ask for the address and contacts. Thanks
Offline sparkbt
« Reply #35 on: July 15, 2011, 02:15:05 PM »
My Aircon compressor up-the-lorry on 9 Jul 11 half way to JB. Went to a 1 shop in JB to check and found that 1 fuse under ECU, controlling the aircon, burnt. Replaced it and aircon compressor start working. After running a while, the mechanic touch the fuse again and comment that it is very hot and told me the fuse will burnt again due to compressor having problem. I touched it and indeed very hot. He manage to get 1 compressor, used by M'sia Lavina/1.5 latio(S'pore) made in M'sia. He commented that there is only 1 such compressor in the market for 1.5l nissan latio in M'sia.
Bargain with him and settle at RM800 with following :
1. Aircon compressor
2. cabin filter
3. dryer
4. Chemical clean on Condenser
5. Top up aircon gas
Offline phant
  • LATIO ALL THE WAY
« Reply #36 on: August 25, 2011, 11:27:36 AM »
I got this probelm and recently rectifed.
The compressor wasnt engaged..
The valve which is suppose to engage to compressor fails.
Therefore, bearing and valve were change and now under hot sun also ok.
Francis aka phant
Offline fessm
    • Shopping for ladies
  • Car Color: Red
« Reply #37 on: September 12, 2011, 11:12:29 AM »
I have last mentioned my aircon is failing me 2 months ago, then last Thursday, it totally died, no cold air at all.
The hissing sound will be there constantly.
So I went to change my cooling coil last sat morning, total damage is $460.
Cost includes cooling coil, filter, gas topup, labour, gst.
It took them ard 3 1/2 hrs to complete.
Location is at Tomika Bukit Merah, they have another shop at Ubi.
Quite satisfied for now, although not the cheapest if compared to the bros posted above.
Shall monitor for the next few months  :yehyeh: :yehyeh: :yehyeh:
Offline ooi_eddie
  • Car Color: White
« Reply #38 on: September 13, 2011, 11:26:13 PM »
Got this air con problem also.  Air con suddenly blowing hot air.  I off the air con for a minute and on it back, the air con blow cold again. After a few minutes, the same problem occur again.
When to a workshop in JB and check told them the problem. Directly he can pinpoint the magnet coil faulty. After checking and is true that the 'Magnet Coil' in the compressor is faulty. .
Option 1 : Change Magnet coil at RM280
Option 2 : Change re condition compressor with the magnet coil at RM550++
Opt for magnet coil changed at RM280 and it took about 2 hours
Now my latio aircon is normal. hopefully is will last for a while.
Offline linus
  • Car Color: Grey
« Reply #39 on: September 23, 2011, 09:25:46 PM »
Just changed my cooler coil, filter, valve and top up gas plus normal air con servicing <400 at Kim Aircon.  Just a few shops away from Tomika at Ubi.  Highly recommended.  Look for the boss, Mr Loo or Ah Khim.  He is knowledgeable and will give you genuine advice.  Price is very reasonable as well.  TC quoted me >550.
