Author Topic: short " Ji " sound when engine start  (Read 7415 times)
Offline rocket
« on: July 15, 2011, 09:54:50 AM »
replaced fan belt last week at outside workshop, now when  engine start, there is a short "ji" sound from engine compartment, suspect from the belt.
just wondering, after belt replacement,  any alignment or adjustment need to do?
Re: short " Ji " sound when engine start
« Reply #1 on: July 15, 2011, 10:03:55 AM »
You need to go back the workshop and tighten the belt.
« Reply #2 on: July 15, 2011, 01:41:45 PM »
Normal, most workshop do not over tighten the belt during initial installation, just go back like robtan99 mentioned.
Offline rocket
« Reply #3 on: July 15, 2011, 08:08:30 PM »
thanks for the info?
BTW, any gauges for the belt tension during installation?  it is harmful when the belt is loose?
« Reply #4 on: July 21, 2011, 03:23:52 PM »
Loose belt causes squeaky sound in the mornin when engine is cold, get it adjusted to the right tension & everytin will be fine
« Reply #5 on: July 22, 2011, 10:16:23 AM »
For my case, it also occurs when the engine is cold like in the morning.
Offline quirky
« Reply #6 on: July 22, 2011, 01:46:38 PM »
I hear a "ti" sound when I switch on the air con. Is this normal?
« Reply #7 on: July 22, 2011, 06:01:12 PM »
yes that is normal.cause compressor cut in that caused that "ta "noise
« Reply #8 on: July 23, 2011, 02:47:51 PM »
Wait till when your compressor is a few years old and you will start hearing the breathing sound in the cabin. (When the compressor cut in and out)
