Author Topic: [Advice needed] Is my RPM readings normal?  (Read 12028 times)
Offline noob
« on: September 12, 2011, 02:02:49 PM »
My ride (4AT sedan) is currently reaching 5 yrs old with mileage around 18K, servicing is done quite regularly at TC on every interval of 8-9months .  Everything is stock except that I upsized my rim n tyres last Nov.  It was changed from stock 15" to 16" (Rims from Stamford tyres) n tyres is CPC2 205/55/R16.
Qns:
I noticed yesterday when I was on the expressway, when I accelerate to 105-110, my rpm went up to 2.8K and when it hit 120, rpm was around 3.2K.  I'm not sure whether my rpm went up so high before (on 105-110) last time but it does feel abit weird to me , so thought of posting here to gather some feedback.  Thanks
Re: [Advice needed] Is my RPM readings normal?
« Reply #1 on: September 12, 2011, 05:44:42 PM »
Qns:
My ride is on 205/50/16 Falken 912. 2K RPM when on ~80 kmh. I think yours is a bit too high. Were u going up a slope when you took the readings?
Offline noob
« Reply #2 on: September 12, 2011, 06:02:07 PM »
Nope, don't think I'm on a slope.  I was on TPE...direction heading towards Changi.
« Reply #3 on: September 13, 2011, 09:08:21 AM »
Ok, u may want to send in to your workshop for a check. Dun think that is normal; i stand corrected (:
« Reply #4 on: September 13, 2011, 10:34:44 AM »
what is the load in the car? accelerating & cruising is quite different rpm.....
Offline noob
« Reply #5 on: September 13, 2011, 11:09:05 AM »
Single adult - Driver.
Boot - spare tyre n some car washing chemicals.
Backseat - 2 baby car seat.
Don't think it was accelerating as I was not stepping hard on the accelerator.
Offline spyder_696
« Reply #6 on: September 14, 2011, 01:56:01 PM »
how about any indicator lights lighted up on the instrument panel...
Offline noob
« Reply #7 on: September 15, 2011, 11:16:10 AM »
Nope, don't have any warning or indicator signs lighted up.
Offline kt
  • Car Color: Amethyst Grey
« Reply #8 on: September 19, 2011, 05:53:11 PM »
Yr RPM is not normal. Did u change battery/ clean yr throttle body/ change air filter recently?
Offline noob
« Reply #9 on: September 20, 2011, 04:39:51 PM »
Battery (dry) was changed about 1yr ago.  Throttle body cleaning n air filter changing - no idea but i do sent in for servicing quite regularly.
Did another test last weekend, cruising on tpe, hit 2.4K rpm on 100.  Compared with a fren whom is driving the same model (except that his tyres n rims r stock - 195/65/R15), he also achieved the same rpm at that speed.  However, this should not be the case as I thought bigger rims means lesser rpm will be achieved on the same speed as compared to another vehicle on a smaller rims size.
Offline kt
« Reply #10 on: September 22, 2011, 08:55:16 AM »
Maybe u can take yr air filter out and check if it has warped/ tear/ dirty. If nothing wrong with air filter, thn better send to a workshop to do diagnostic tests. Yr RPM is definitely pretty high.
Offline m_k_tang
« Reply #11 on: September 22, 2011, 11:04:59 AM »
For Auto gearboxes, CVT and 4 Speeds are very different. From description, usually 4 speeds auto will have higher RPM (for example at 100km/h) as compared to CVT gearbox. Just like the case for my Honda Civic with 5 speeds auto gearbox, hitting at 100km/h will be around 1.9k RPM. Of course, lower RPM at higher speed will result in better fuel efficient and saving. Which is why, many car manufacturers recently come out with 6, 7 or even 8 speeds auto gearboxes in their new car models and of course, their newer models will be more expensive with new techology and equipment.
