Author Topic: Liquid Capacity for Latio  (Read 12549 times)
Offline dm
  • Car Color: Clear
« on: October 18, 2011, 11:31:35 AM »
Guys, i getting my latio this weekend, will be changing oil, atf and coolant.
How many Litres is needed for engine oil (with and without filter), transmission fluid and coolant?
sorry my car didn't come with the manual and the workshop i going to carry some weird brand of oil and i rather buy myself.
Offline marcellim
Re: Liquid Capacity for Latio
« Reply #1 on: October 18, 2011, 03:52:11 PM »
just did my servicing yesterday.
4 litres of engine oil and 4 litres of ATF should be enough.
not sure about coolant because I did not change.
Offline andromeda2000
« Reply #2 on: October 18, 2011, 04:17:37 PM »
Engine oil is 3.3L according to manual. Recommended grade is 5W30.
Oil filter should be change at every servicing.
Offline dm
  • Car Color: Clear
« Reply #3 on: October 19, 2011, 08:04:46 AM »
for transmission fluid, what brand you all using? anyone knows where to buy the mobil fully synthetic atf ?  :confused1:
Offline Enzoni
« Reply #4 on: October 19, 2011, 09:40:35 AM »
engine oil only need 3 quarts or 3 x 946ml.  Buy 4L = waste money.
Offline dm
  • Car Color: Clear
« Reply #5 on: October 20, 2011, 07:43:03 PM »
so it's 3.3L with or without the oil filter?
Offline Enzoni
« Reply #6 on: October 21, 2011, 07:26:50 AM »
Buy those engine oil that comes in smaller bottle (1 US quart), normally 3 bottles will do. If u afraid not enough, then buy 4. If 4th one not needed, can keep for next servicing. If u buy 4L big bottle, u will have leftover...
Normally 1 quart only $10plus eg. mobil1, redline, amsoil etc. I bought mobil1 0-w40 from carrefour for my last servicing, around $12 or 13 for 1 quart, not much difference from the $17.50 redline n amsoil i used before.
As for transmission, u must make sure u r not buying normal atf oil if ur latio is cvt transmission.
« Last Edit: October 21, 2011, 07:30:30 AM by Enzoni »
Offline dm
  • Car Color: Clear
« Reply #7 on: October 21, 2011, 09:40:30 AM »
Offline Enzoni
« Reply #8 on: October 21, 2011, 12:24:30 PM »
 :cool2:
Offline dm
  • Car Color: Clear
« Reply #9 on: October 24, 2011, 02:58:39 PM »
i just bought the manual, it says 3.3L with oil filter and 3.1L without.
« Reply #10 on: October 24, 2011, 06:11:40 PM »
correct. 3.3l is with oil filter.as for ATF,normal auto gearbox can use any type.but CVT you must used back CVT fliud.that is NS2 in blue colour tin.
Offline Enzoni
« Reply #11 on: October 24, 2011, 06:51:51 PM »
so u got to buy 3 quarts plus a little bit more haha  :w00t:
are you a first time car owner?
Offline dm
  • Car Color: Clear
« Reply #12 on: October 25, 2011, 09:09:00 PM »
yes because engine oil is sold by the litre. are you trying to gek ang moh by using quarts? :out:
Offline cutelmo
  • Car Color: AMETHYST GRAY
« Reply #13 on: October 28, 2011, 11:03:47 PM »
Hi, just wondering where you bought the manual?  ;D
