Author Topic: Aircon blowing out warm air  (Read 22166 times)
Offline tahoo
Re: Aircon blowing out warm air
« Reply #20 on: January 25, 2012, 11:26:16 PM »
My aircon was blowing intermittent hotair.  Went to aircon specialist at Autobay, mechanic said compressor clutch plate worn off.  Learnt that the compressor actually has a clutch plates with a paper-thin washer in between.  Mechanic removed the washer so that the plates has bettter grip and my aircon back to normal.
Interesting sharing. Do you still remember how much did they charge u?
« Reply #21 on: January 26, 2012, 11:29:12 AM »
hi Anaconda,did the mechanic remove out your compressor from the car to do it or they do it with out removing it,if they removed it out from the car then its not the compreesor fault cause after taking out ,they need to top up the gas,once gas enough its cold again.once the compressor don't cut it,you need to change the whole clutch assy.
Offline froggiee
« Reply #22 on: January 26, 2012, 02:27:06 PM »
After driving for more than 5 years, the compressor finally up lorry. Replaced at Autobay for <500. As for my friend the mechanic just clean the clutch so far so gd. If those who aircon sometime cool and then not. If u try to ramp yr car and it get cool. then maybe just need to clean the compressor clutch. Just for sharing.
Offline Anaconda
« Reply #23 on: January 26, 2012, 09:44:50 PM »
Quite cheap.  I think $50 or $70 nia, including adding of compressor lubricant.  About 30 mins job.
Offline Anaconda
« Reply #24 on: January 26, 2012, 09:48:41 PM »
Mechanic did not remove compressor out.  They jack up car and crawl underneath to remove the washer.  The washer about ten cent coin size, black in colour and thin like paper.
Offline karkadyz
« Reply #25 on: January 31, 2012, 04:07:23 AM »
got lobang to change cooling coil,thermo sensor,a/c gas and labour for changing it at $500 only.interested can pm me. :yehyeh:
hi.... can share your lobang? thanks
« Reply #26 on: February 01, 2012, 10:52:44 PM »
knn my aircon got hissing sound non stop n no cool air
any recommended place?
« Reply #27 on: February 02, 2012, 06:18:09 PM »
yap pm me your contact no. and i'll arrange with u. :yehyeh:
