Author Topic: Bad FC for past 1Mth+  (Read 13574 times)
Offline latiowner
« on: July 02, 2012, 02:30:05 PM »
Juz check, my Latio CVT sedan are in the 5th year liao. Recently, my FC had been quite poor which run less than 400Km for past 1 mth+, used to be 400-420Km. Any particular reasons or advice? Didnt mob any parts of the car and has been regular service every half year.
Re: Bad FC for past 1Mth+
« Reply #1 on: July 02, 2012, 02:40:32 PM »
spark plug changed?
Offline latiowner
« Reply #2 on: July 02, 2012, 05:26:38 PM »
Not yet, i was told spark plug change at 100Km...mine reach around 90000km+. Maybe is time to change....Besides spark plug,  any other advices as I'm going for car services this month.
Offline dthh
  • Car Color: RED
« Reply #3 on: July 02, 2012, 05:33:17 PM »
Check your air filter also. Did you do alot of idling or traffic jam?
Offline bakoh79
  • Car Color: Pearl-White
« Reply #4 on: July 02, 2012, 05:34:02 PM »
I noticed my FC is better whenever i travelled long distance on expressway, compared to normal roads..
Maybe u changed ur routing too??
Offline latiowner
« Reply #5 on: July 02, 2012, 10:32:16 PM »
Air filter changed when doing half yearly servicing......travel route wont be the same as used it to reach my customer place on and off. I will say about 40% expressway, 60% city. But for past 5 year, my FC havent been that bad.....  :confused1:
Offline twelfth
    • pictures
« Reply #6 on: July 02, 2012, 11:50:40 PM »
could it be due to hot weather, sometime i did encouter bad FC but will back to normal after sometimes.
my constant FC is around near 11 most of the time city driving.
My FC sampling
http://www.freeimagehosting.net/l7urb
[img width= height=]http://www.freeimagehosting.net/t/l7urb.jpg[/img]
« Last Edit: July 03, 2012, 12:00:51 AM by twelfth »
Zoom first talk later
« Reply #7 on: July 03, 2012, 01:36:40 PM »
how about tyre pressure?
Offline gunner1976
« Reply #8 on: July 04, 2012, 11:46:20 PM »
hi,
same issue as u... happened after i did 100,000km service. changed new spark plugs(stock), air filter, 5w-30 EO. FC really bad..
Offline d.titan
« Reply #9 on: July 05, 2012, 05:37:14 AM »
Used to get 13-15km /L
After change to better grip tyre, same size,
FC change to 11-12/ L
 :confused1:
But the braking improves
 :yehyeh:
« Reply #10 on: July 05, 2012, 07:31:11 AM »
hi,
i thought after a certain milage, we should be using w40 oil?
i think i have been using w40 oil for some time even before my  100k service, and my fc still sama sama from day 1.
« Reply #11 on: July 06, 2012, 04:28:35 PM »
Check if your fuel gauge is working properly.
Mine die last month and have the float replace.
« Reply #12 on: July 07, 2012, 01:16:05 PM »
Fuel gauge nothing related to FC. You only need to use distance travelled divided litres of petrol pumped.
« Reply #13 on: July 07, 2012, 01:43:11 PM »
I was on 0w40 oil since hitting 80k mileage mark, n yes car n drive experience is better. usin shogun oil
Offline gunner1976
« Reply #14 on: July 11, 2012, 12:24:25 AM »
yup, will be switching to w40 the next service. anyone tried redline EO before?
« Reply #15 on: July 11, 2012, 09:11:22 AM »
use 0W40 for the past 4 years, tried TCM Shogun, Carlube, Agrip, AMSoil, astro boy, valvoline and other brand that I cant recall.
Best experience : valvoline (with engin flush, autosaver) then astro boy.
If I mainly drive in city with W40 oil then full tank can reach ~300+km
Highway within speed limit can reach 500+km per tank.
Offline kt
  • Car Color: Amethyst Grey
« Reply #16 on: July 11, 2012, 03:41:58 PM »
I'm currently using Redline 5W30. Car's pickup and engine response much much better than the EO TCM used. FC also improved slightly. My mileage is now about 150k.
Offline gunner1976
« Reply #17 on: July 13, 2012, 12:31:37 AM »
Hi...
thanks for the feedback...some bros commented to use w-40 EO after certain mileage.
Offline latiowner
« Reply #18 on: July 13, 2012, 02:04:23 PM »
Had gone for 90K service on Wed. Autosaver juz do routine 90K service,engine flush, change aircon filter and ask me to monitor as he didnt found any major problem on my car. Using 0W40, should be Mobil synthetic oil. Will monitor 1-2 month for the FC.
Offline quirky
« Reply #19 on: July 21, 2012, 09:20:26 PM »
My FC went down from 13.x (Sometimes 14.x) to around 11.5 after I changed my Toyo stocks! :(
