Author Topic: Spark plugs change  (Read 13005 times)
Offline joyrob
Spark plugs change
« on: September 05, 2012, 11:28:20 PM »
Hi all
Have reached my 100k milestone. Mechanic advised need to change spark plugs. Quoted 200 for material and labour. Is it expensive for this ? I heard latio spark plugs not easily changed, as have to removed quite a lot of things.
Offline Enzoni
Re: Spark plugs change
« Reply #1 on: September 06, 2012, 07:53:06 AM »
$200 all in is good price, for normal usage drive latio for 10 years only need to change spark plug once at 5 year mark.
Offline edmundteo
  • Car Color: Silver
« Reply #2 on: September 06, 2012, 09:08:42 AM »
Try get the plugs from other source which cost about $110 for a set of 4 and get the workshop that service your car to change. Labour usually charges between $30 to $60.
Total may cost around $150 and the balance can still pump petrol....probably 3/4 tank.
Offline dareindie
« Reply #3 on: September 26, 2012, 10:05:50 PM »
By the way, check with all bros, after changing the spark plugs, do we need to reset the computer unit? Thks!
Offline IvanL
  • Car Color: Grey
« Reply #4 on: September 26, 2012, 10:54:09 PM »
Yes bro. You need to reset your ecu about $50- 60 usually. I changed my spark plugs at kelvin bro's workshop about 2 months ago.
Will recommend you ask him for a quote.
« Reply #5 on: September 28, 2012, 05:12:09 PM »
Cheapest qoute i got for Denso plugs $22.50 per pc
Ngk not advisable to get
Offline 180er
« Reply #6 on: November 05, 2012, 03:43:45 PM »
I just had my spark plugs replaced Iridium and throttle cleaned. Idling too high but mechanic said to drive for a few days as the computer will usually self-adjust. Your thoughts?
« Reply #7 on: November 05, 2012, 08:21:18 PM »
Yep, ECU need to re-learn your driving habit again. No worry.
You may also faced a higher FC for this tank and next.
« Reply #8 on: November 06, 2012, 09:58:42 PM »
My spark plugs were replaced without a single charge while I am on NPMP. Worth It
« Reply #9 on: November 06, 2012, 10:25:02 PM »
After throttle clean,u need to do a ECM reset.
Offline 1258
« Reply #10 on: November 30, 2012, 09:45:01 AM »
I have just done my servicing & spark plugs @ Bro kevin workshop last mth.   :thumbsup:
Offline Dec7f
« Reply #11 on: April 23, 2013, 11:48:46 PM »
On NPMP, change of spark plugs is at which mileage interval, 10K?
Bought a 2nd hand latio, the servicing history didn't indicated any change of sparks plugs.
Car's cuurently up for 54k servicing & TC recommended i go for package B -  change of sparkies with additional charges...
Any idea what sparkies to use for latio 4AT?
Spec?
Thanks :thumbsup:
Offline jasonkstan
  • Car Color: GREEN
« Reply #12 on: April 24, 2013, 01:13:12 PM »
DENSO FXE20HE11
Offline Dec7f
« Reply #13 on: April 24, 2013, 02:30:37 PM »
DENSO FXE20HE11
Thanks :thumbsup:
Any npmp users can kindly advice any changes of sparkies during 0~40k mileage?
« Reply #14 on: April 24, 2013, 03:31:11 PM »
Thanks :thumbsup:
i am not on npmp but the recommended interval for change is 100K km for the plugs.....
my car is now 180K km and i change at 100K & 160K (cos car left 2yrs so change earler rather than later)
« Reply #15 on: May 01, 2013, 02:53:35 AM »
Stock cars no need changevspark plug unless reach 100k. When under npmp it is replace free
