Author Topic: Air con problem  (Read 38309 times)
Offline latiowner
Re: Air con problem
« Reply #20 on: March 01, 2013, 10:42:34 PM »
yes, it is original part from nissian.
Offline edwardtkh
Re: Air con problem
« Reply #21 on: March 04, 2013, 02:09:44 PM »
Just changed my compressor at MarkCool this morning. Total damage 560. Now aircon is back to normal and very cold  :yehyeh:
Ride is 7yrs old ++
For those interested to know how your compressor looks like, here's the pictures. It's hard to find via Google or Yahoo so I guess for the convenience to all..
Old Compressor
New Compressor
Re: Air con problem
« Reply #22 on: April 11, 2013, 05:15:44 PM »
Compresser up lorry soon, as it not kick in anymore. :(
Compressor still going strong
Probably a slow leak
Gas topped up & now cold
Will continue to monitor
Offline tsc2828
Re: Air con problem
« Reply #23 on: July 07, 2013, 12:12:00 PM »
Confirmed. Anyway, the main prob is not enough gas. Where leak I dunno but very likely to be cooling coil. Changed mine @ Kelvin's workshop (really recommended)  :thumbsup:
Can pm ME WHAT IS THE DAMAGR?
Offline wooks
Re: Air con problem
« Reply #24 on: July 08, 2013, 11:06:10 PM »
Where to check and top up gas?  And how much is top up cost?
« Last Edit: July 09, 2013, 10:27:51 PM by wooks »
Offline tsc2828
Re: Air con problem
« Reply #25 on: July 20, 2013, 09:50:23 PM »
top up gas 20
Offline wooks
Re: Air con problem
« Reply #26 on: July 29, 2013, 06:20:17 AM »
How much to change compressor? Recon price? Or original price?
Re: Air con problem
« Reply #27 on: July 29, 2013, 06:59:40 AM »
compressor price is about 500 to 600, new set.
Offline wooks
Re: Air con problem
« Reply #28 on: July 29, 2013, 10:21:04 PM »
Wow, when should it be change?
Offline jonchar
Re: Air con problem
« Reply #29 on: September 25, 2013, 05:22:57 PM »
Aircon also blowing hot air recently. Changed cooling coil as leaking for $400 and new compressor for $560.
Offline cutelmo
  • Car Color: AMETHYST GRAY
Re: Air con problem
« Reply #30 on: December 14, 2013, 02:42:38 PM »
Hi All,
I was wondering beside compressor and cooling coil, what other factor or parts that will make the air-con not cold?
Radiator?
Re: Air con problem
« Reply #31 on: December 14, 2013, 09:19:49 PM »
Radiator is to cool engine
Offline WONWON
  • Car Color: white
Re: Air con problem
« Reply #32 on: December 21, 2013, 07:04:15 AM »
There are 3 sensors in the air con system, one of mine was faulty, as a result 25 DC and 18 DC had the same level of chillness.
Offline cutelmo
Re: Air con problem
« Reply #33 on: March 29, 2014, 11:31:15 PM »
Think my radiator also up lorry liao.
Anyway, anyone happen to hear/use this K-seal product? It seems like it can seal up those leaks.....
Offline edlis
Re: Air con problem
« Reply #34 on: April 08, 2014, 03:40:44 PM »
Anyone can advise on the cost to change the cooling coil.  Was quote $600 at a workshop in Loyang. thanks
Offline valles
  • Car Color: White
Re: Air con problem
« Reply #35 on: April 10, 2014, 05:20:15 PM »
$350 at Kelvin's workshop as per last dec pricing.
Offline cutelmo
Re: Air con problem
« Reply #36 on: April 11, 2014, 12:07:04 PM »
For those who on their aircon, usually will have a "thun" sound coming from compressor in normal working conditions.
So for those who on their aircon but did not heard this sound, most likely is the compressor got shorted.
I got this problem when travelling from one area to another area and the aircon was working fine, park there for a few hours and start engine hot air blowing out again. Did not heard the sound. After diagnose at one of the WS, found that is compressor problem.
The person just use a tester to test on the fuse and the fuse was open. He inform just change 1 of the part in compressor (repair) and top up gas. Now working fine.
Meaning to say, actually no need to change out the compressor which I did about 3 years back. Just change one part inside compressor ok liao.
Offline dthh
  • Car Color: RED
Re: Air con problem
« Reply #37 on: April 11, 2014, 01:13:27 PM »
This seem very intersting....
Can share more?
Like..Do we need to remove the compressor, How long the repair need, Cost of repair....
Lastly...Where is the workshop?
Thanks....
Offline rongshu
Re: Air con problem
« Reply #38 on: April 11, 2014, 03:37:36 PM »
Maybe I can share my problems so others can also benefit.
My car was about 5 years old, and aircon started not able to cut in (no "thun"sound) when in jam like causeway to JB. But when checked at workshop, the aircon worked fine. It happened more frequently after that. Even while waiting in the car, the aircon would not cut in. So my problem with aircon is only not cool during jam/stationary and under hot sun. I went to Tomika @Alexandra and they changed the compressor magnetic clutch @200.
All went well for another 6 months, then after another long 1 hour jam at causeway, the aircon totally not able to cut in. Went to Kelvin's workshop and they showed me the fuse broken and advised me to change the compressor. Now the aircon cools much faster than before. Hopefully it can last me a few more years.
Offline derrick213
Re: Air con problem
« Reply #39 on: May 15, 2014, 12:54:27 PM »
less than a year after changing cooling coil.. aircon start to have hissing sound on driver side again... =(
