Author Topic: Top overhaul for Latio  (Read 12516 times)
« on: November 25, 2015, 08:06:44 AM »
my ride extended COE for 5yrs.....now engine consume oil and coolant.....just changed radiator in Aug
w/s recommend to do top overhaul
any suggestion on reliable workshop?
Re: Top overhaul for Latio
« Reply #1 on: December 02, 2015, 10:33:30 AM »
Thanks to 1 of the sponsor workshop...
my car is fixed now without the need for overhaul
some coolant hoses leaking behind engine block which cause engine to run hot which explains the fluid losses
changed cvt oil as well and now car is as good as can be.....
going to continue to monitor
Thanks YS
Offline DinoBravo
  • Car Color: Gold
« Reply #2 on: April 02, 2016, 04:50:11 PM »
Could you please PM me share the workshop? Thanks!
« Reply #3 on: April 04, 2016, 07:59:57 AM »
Txxhnic Workshop....look for Yee Seng
1 of our sponsor workshop.....
Offline wil
« Reply #4 on: April 05, 2016, 10:21:15 AM »
HI,
 I did mine at autoaid due to engine consume engine oil and caused a lot of foul plugs... had to top up engine oil every weekend about to give up and scrap untIL I found this... open by ex-tcm general Manager and mechanics all from tcm as well....paid around 2k inclusive of gst. I was quoted by another workshop for a min 5k... Till now monitorin for 3 months and no more leaking.....
Offline Timothy goh
  • Car Color: red
« Reply #5 on: August 07, 2016, 04:08:41 PM »
Is topping up engine oil a common problem for Nissan Latio.
My car is almost up for scrap, but I am thinking of extending the CEO for another 5 years due to the nature of my Job. I have been topping up the engine oil every 3 weeks for the last one year and did not thing anything about it (ignorance is not bliss I guess).
Those of you who have the same problem, did the fix by your workshop work ?
Only the engine oil needs topping up, the coolant water is fine.
Any advice?
Thank you,
Timothy
Offline inspiring1804
  • Car Color: White
« Reply #6 on: August 07, 2016, 08:53:23 PM »
Hi Timothy. its quite amazing to me u can endure topping up engine oil every 3 weeks for the past 1 year.  What is your mileage of the car?
Offline kenmaine1008
« Reply #7 on: August 08, 2016, 12:58:12 AM »
hi bros, can state what is your mileage when engine starts to 'eat' engine oil at a faster than normal rate? TIA.
Le Kua Simi? (x 2)
see my super chio rim~
Le Kua Simi?
my car more swee~
Offline wil
« Reply #8 on: August 13, 2016, 09:10:44 AM »
Your case is almost like mine... The topping up of the engine oil begins once/month... Then frequency becomes 3 times per month followed by weekly... When the frequency becomes higher. I started having misfiring issues. My problem is due to the gasket seal in the engine is wear and tear which resulted the EO to get into the plugs.  Did the overhaul for the engine and problem is solved. No more EO disappearing now(has been about 8 months after overhaul).
The mileage that first started is only abt 100k. This really depends on the condition and luck.. Really unlucky that it came so fast.
« Reply #9 on: August 15, 2016, 11:08:36 AM »
where did u do the overhaul? cost and downtime?
Offline wil
« Reply #10 on: August 27, 2016, 07:13:39 AM »
I did mine at Autoaid, for 2k and downtime about 4 days.
