Author Topic: Drive shaft  (Read 39895 times)
Offline rongshu
Drive shaft
« on: March 02, 2018, 12:31:22 PM »
I have this pop sound from the driver side front wheel for about 1 year. I will hear the sound when brake hard to stop or turning during reversing. Went to workshop and was advised it was drive shaft problem. Anyone has the same problem?
Re: Drive shaft
« Reply #1 on: March 03, 2018, 01:53:28 PM »
Drive shaft ? Do Latio have it ? Latio is FWD not RWD leh.  :confused1:
Read this to understand more.
https://mechanics.stackexchange.com/questions/6688/what-is-the-purpose-of-a-drive-shaft
« Last Edit: March 03, 2018, 02:02:06 PM by Jazz »
Re: Drive shaft
« Reply #2 on: March 03, 2018, 02:07:34 PM »
Offline rongshu
Re: Drive shaft
« Reply #3 on: March 05, 2018, 08:46:24 AM »
From my google search, drive shaft is to transmit the power from gearbox or differential to wheel. So for latio, it has 2 drive shafts. The CV joint is part of the drive shaft. Often there is no separate CV joint alone to replace. I haven't checked with the workshop to see if it is possible to change the CV joint alone. I agree it is usually the outer CV joint nearer to the wheel need to be replaced rather than the whole drive shaft.
Re: Drive shaft
« Reply #4 on: March 17, 2018, 10:58:38 PM »
Changed ? Conclusion ? Curious to know too.
Offline rongshu
Re: Drive shaft
« Reply #5 on: March 19, 2018, 10:16:36 AM »
Not changed yet. Will wait and see if the sound getting more often or getting worse.
Offline magicbrain
  • Car Color: Red
Re: Drive shaft
« Reply #6 on: May 30, 2018, 04:28:38 PM »
Same as me. i buey tahan the sound and changed. drive shaft issue. mechanic says very common among nissan cars.
Offline skullcap
  • Car Color: Amethyst Grey
Re: Drive shaft
« Reply #7 on: June 04, 2018, 01:44:04 PM »
Recently started hearing this knock sound from front wheel drivers side when braking or start off from stand still. I tot it was fr suspension or other rubber joints deteriorating. Din realize it was e drive shaft.
Offline rongshu
Re: Drive shaft
« Reply #8 on: June 04, 2018, 02:41:54 PM »
I haven't change mine yet so cannot confirm if the sound is caused by drive shaft. For my case the sound actually didn't occur most of the time so I just leave it.
I have message magicbrain what he actually changed was the steering coupling. I have that tok tok sound from steering for many years and just ignore. May get the steering coupling changed later this year.
Offline skullcap
Re: Drive shaft
« Reply #9 on: June 06, 2018, 08:49:23 PM »
Ohh...then it may nt b e drive shaft. Steering coupling I know coz I’ve hd it for yrs n just bear wth it. So my noise cud b smethg else..??🤔
Offline skullcap
Re: Drive shaft
« Reply #10 on: July 08, 2018, 07:29:12 AM »
Found e problem to my car. It’s e lower arm on e driver’s side, where it connected to e wheel. When lift up car, e right front wheel has a loose play. Change both lower arm, now all fine ord.
Re: Drive shaft
« Reply #11 on: July 08, 2018, 02:31:45 PM »
 :thumbsup:
Offline rongshu
Re: Drive shaft
« Reply #12 on: July 31, 2018, 10:04:31 AM »
Great, maybe I should have the lower arm checked also. Recently the pop sound getting more often when I brake or move off.
Offline rongshu
Re: Drive shaft
« Reply #13 on: July 31, 2018, 10:07:16 AM »
How much for both lower arms?
