Author Topic: Newbies HELP thread, ask vypez anything!  (Read 233823 times)
Offline vypez
    • need help with words?
« Reply #220 on: September 21, 2008, 10:03:23 PM »
Hi all
Need someone's help to confirm the specs of the stock 15 inch Latio rim -  think its 4x100 ? What about the offset, centre bore and width ?
Is there any difference in specs between the Sports, Basic and Premium versions' rims ?
Thanks !
honestly, i got no idea. probably because no one has ever really bothered to find out as well.
and by stock 15" rims, which one are you referring to? and yes, ALL the version's rims are different. the only one worth keeping?
the impul 15" enkei.
Offline JLHeng
« Reply #221 on: September 28, 2008, 06:47:54 PM »
Hi Bro Vypez,
May I know where can I install the spark bridge? Pls advise.
Thanks and Regards,
JLHeng
« Reply #222 on: September 28, 2008, 09:49:50 PM »
What is our Latio wheel offest ? We can change to any rims using different offset accordingly ?  :smile:
Offline vypez
« Reply #223 on: September 29, 2008, 10:57:36 PM »
Hi Bro Vypez,
Thanks and Regards,
JLHeng
i believe this is something i can help you with.
do drop me an sms @ 91544534.
Offline vypez
« Reply #224 on: September 29, 2008, 10:58:52 PM »
this one, you've got me. i got no idea honestly.
probably +42 is a safe bet as i am assuming stock is usually +48. +42 will give you a slightly more flushed look.
« Reply #225 on: September 29, 2008, 11:44:28 PM »
So if we use the wrong offset, is there any impact or consequences that might happen ?  :unsure:
Offline JLHeng
« Reply #226 on: September 30, 2008, 10:35:50 PM »
Thanks bro, will sms tomorrow.
Offline vypez
« Reply #227 on: October 04, 2008, 10:01:28 AM »
hmm, not really. prob the most obvious is slight increase in turning radius
« Reply #228 on: October 06, 2008, 03:53:34 PM »
Hello vypez,
Do you know if Latio has the OBD2 com port ? If yes do you know where is it located ? Thanks.  :smile:
Offline vypez
« Reply #229 on: October 08, 2008, 12:26:18 PM »
Hello vypez,
every car sure have. or else how to diagnose?
its under your steering column.
Offline Huatster888
  • TAI KAY LAI HUAT AR!!!
« Reply #230 on: October 27, 2008, 08:25:02 PM »
yoyo.......wher to get spring stiffeners??how much isit also??i wana get a pair n lup behind leh...sad latio kantong sibeh soft
thereds
« Reply #231 on: October 28, 2008, 09:27:51 PM »
Vypez,
I read a few posts in the "My FC getting worse" thread and am a little confuse about the FC for Latio. Quite a few claimed that the FC actually drop. Can you comment on this? Or was it minority?
Thank you...
Offline vypez
« Reply #232 on: October 29, 2008, 05:57:56 PM »
search for this guy called clarkewan. he installs @ $160 for 4.
Offline vypez
« Reply #233 on: October 29, 2008, 05:59:40 PM »
Vypez,
Thank you...
actually not to worry. humans control the car. depending on us, the car performs accordingly. of course, some factors do play a part such as outside temperature, road surfaces and such.
basically, what i am trying to say is fc really depends on you yourself. if you use 10w50 oil, dont expect fantastic fc. =]
thereds
« Reply #234 on: October 29, 2008, 11:11:12 PM »
Thanks for the prompt reply, Vypez.
My next question is about CVT. Read a thread that a few bros actually changed CVT.
If I am not wrong, Honda also withdrawn CVT in Jazz because CVT has too many issues.
Would you be able to comment about Nissan CVT? It's scary if the CVT breakdown after warranty.
Thanks in advance...
Offline vypez
« Reply #235 on: October 31, 2008, 03:13:18 AM »
cvt is still unstable until now to be exact.
but no worries, my guess is probably you wont be keeping the car for more than 7 years and you're probably not using your latio for tracking.
benjamin00000
« Reply #236 on: October 31, 2008, 08:07:10 PM »
why is using 10w50 oil the FC will be bad?  :confused1:
Offline vypez
« Reply #237 on: October 31, 2008, 09:15:32 PM »
because if you look at oil,
w30, w40, w50... is in terms of viscosity of the oil. meaning, the thickness. more protection, at the cost of more energy needed to power up.
understood bro? its like you walk in water and walk in mud. =]
clementiboy
« Reply #238 on: October 31, 2008, 10:59:28 PM »
Hi Vypez, a noob question. How do I know if the leather seats in my Latio (the new facelift) one is full leather or is synthetic leather?
benjamin00000
« Reply #239 on: November 01, 2008, 02:33:01 PM »
So if we don't mind the FC, its better to use w50, right?  :thumbsup:
